[Mapserver-users] mapserver4.0 compilation under w2000
Michael Schulz
mschulz at webgis.de
Fri Aug 22 14:35:28 EDT 2003
Hi Ed, Gayathri,
But how to make "only" the regex.obj target, there is no such target
(which Makefile do you mean?) - do i have to edit the makefile.in and
add such a target manually?!
Thanks again for your help, i know this is annoying (especially because
i already managed to do it some time ago ;-))
Cheers, Michael
Ed McNierney schrieb:
>Michael -
>regex.obj creates more hassles per line of code than any other file in the Windows build! It's simply a bad makefile.
>Try this - go into the regex-0.12 directory and make ONLY the regex.obj target. This should work fine. Then check/edit your MapServer makefile and make sure that a "make clean" doesn't delete it.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>ed at topozone.com
>(978) 251-4242
>-----Original Message-----
>From: Michael Schulz [mailto:mschulz at webgis.de]
>Sent: Friday, August 22, 2003 10:42 AM
>To: MapServer Userlist
>Cc: kafka at email.cz
>Subject: [Mapserver-users] mapserver4.0 compilation under w2000
>Hi,
>here it comes again: i try to compile mapserver4.0 on w2000 with
>msvc++7. I succeeded a while ago with a mapserv3.7 version. Now i am
>stuck with an error related to the regex library:
>Creating library mapserv.lib and object mapserv.exp
>mapserver.lib(regex.obj) : error LNK2001: unresolved external symbol
>_printchar
>mapserv.exe : fatal error LNK1120: 1 unresolved externals
>Stefan, I cc'ed to you directly since you described the same error some
>months ago, did you solve the problem? Or, perhaps some of the
>windows-mapserver users has a good idea.
>I searched google for a while and only found some references, that
>suggested to include a __STDC__ flag for the regex lib, when using it in
>cpp code, hmm, but i don't know if that could help in this case.
>TIA, Michael
