[Mapserver-users] Freetype problem
Danny Bisson
progigraph.vd at cablevision.qc.ca
Mon Aug 25 11:04:53 EDT 2003
Since we're trying to use Mapserver version 4.0, we have the following
error message:
msGetLabelSize(): TrueType Font error. Could not find/open font
It seems like mapserver finds the fonts.list file but it's not able to open
the font itself. I tried with an alias in the configuration file in Apache
and it doesn't work either. I used the precompiled version of mapserver.
It should manage the truetype itself, I think.
>From our point of view, everything should be ok; the fonts.list file contains:
arial arial.ttf
and arial.ttf is in the same directory as fonts.list
I tried with the full path in the fonts.list and it didn't work either.
I put in the .map file the line containing FONTSET. I tried with relative
path and with full path.
Everything was OK with version 3.5
Note: We're running Mapserver on Windows 2000. I want to have my fonts one
directory before the .map file in a directory called "fonts"
Can you give me some examples.
Thanks
Danny
