[Mapserver-users] PROBLEM with GetFeatureInfo results???
Paul Spencer
spencer at dmsolutions.ca
Tue Aug 26 12:07:51 EDT 2003
Josef, you will need to have a template attribute inside each layer
object that you want to be queryable. It looks something like:
TEMPLATE "ttt.html"
The value "ttt.html" can be any non-empty value. Not sure if it must
end in .html or not.
Cheers,
Paul
Josef Stromský wrote:
>Hi folks,
>Im trying to getFeautreInfo from my MapServer, but Im unable to get some
>results. My mapserv.exe returning this everytime :
>GetFeatureInfo results:
> Search returned no results.
>My request URL is:
>http://158.196.141.84/cgi-bin/mapserv.exe?map=D:/Apache/Apache/htdocs/Wgs84/transcat.map&REQUEST=GetFeatureInfo&VERSION=1.1.0&BBOX=12,47,19,52.25&SRS=epsg:32633&WIDTH=800&HEIGHT=600&QUERY_LAYERS=CRhran_wgs&X=240&Y=242
>Very similar getMap request works fine, but this is mystery for me. Maybe is
>something missing here.
>Thanks so much for any advice.
>Here is my MapFile (it was createt from demo MapFile):
># Start of map file
>MAP
>NAME "TRANSCAT"
>STATUS ON
>EXTENT 12 48 18 51
>SIZE 640 480
>SHAPEPATH "."
>IMAGECOLOR 255 255 255
>UNITS METERS
>IMAGETYPE PNG
># Start of web interface definition (including WMS enabling metadata)
>WEB
>MINSCALE 1000
>MAXSCALE 1550000
>IMAGEPATH "./tmp"
>IMAGEURL "./tmp"
>METADATA
>"WMS_TITLE" "UMN MapServer Itasca Demo"
>"WMS_ABSTRACT" "This is a UMN MapServer application for Itasca County
>located in north central Minnesota."
>"WMS_ACCESSCONSTRAINTS" "none"
>"WMS_ONLINERESOURCE" "http://158.196.141.84/itasca/index.html"
>"WMS_SRS" "epsg:32633"
>END
>END
># Start of reference map
>REFERENCE
>STATUS OFF
>IMAGE "graphics/reference.png"
>SIZE 120 120
>EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
>COLOR 255 0 0
>OUTLINECOLOR 0 0 0
>MINBOXSIZE 5
>MAXBOXSIZE 100
>MARKER "star"
>MARKERSIZE 8
>END
># Projection definition, consult the PROJ.4 documentation for parameter
>discussion
>PROJECTION
># \proj=utm\
># \ellps=GRS80\
># \zone=15\
># \north\
># \no_defs\
># OR:
>"init=epsg:32633"
>END
># Start of legend
>LEGEND
>STATUS ON
>KEYSIZE 18 12
>LABEL
>TYPE BITMAP
>SIZE MEDIUM
>COLOR 0 0 89
>END
>END
># Start of scalebar
>SCALEBAR
>STATUS ON
>COLOR 255 255 255
>IMAGECOLOR 0 0 0
>UNITS METERS
>INTERVALS 1
>SIZE 100 2
>STYLE 1
>LABEL
>SIZE TINY
>COLOR 255 255 255
>END
>END
>#================================== Start of symbol definitions
>SYMBOL
>NAME "circle"
>TYPE ELLIPSE
>FILLED TRUE
>POINTS
>1 1
>END
>END
>SYMBOL
>NAME "star"
>TYPE VECTOR
>FILLED TRUE
>POINTS
>0 .375 .35 .375 .5 0 .65 .375 1 .375 .75 .625 .875 1 .5 .75 .125 1 .25 .625
>END
>END
>#´======================================== Start of layer definitions
>LAYER
>NAME "useky_wgs"
>#GROUP "silnicniDatabanka"
>STATUS ON
>DATA "./SilnicnidatabankaOstrava_wgs/useky_wgs"
>TYPE LINE
>CLASS
>NAME "useky_class"
>#SYMBOL "circle"
>COLOR 0 0 0
>SIZE 1
>END
>END
>LAYER
>NAME "uzly_wgs"
>STATUS ON
>DATA "./SilnicnidatabankaOstrava_wgs/uzly_wgs"
>TYPE POINT
># OFFSITE 31
>OFFSITE 252
>METADATA
>"WMS_TITLE" "Silniční databanka Ostrava"
>"WMS_ABSTRACT" "Hibbing and Bemidji quadrangles. See
>http://deli.dnr.state.mn.us/metadata/full/drgncim1.html for more
>information."
>END
>CLASS
>NAME "uzly_class"
>SYMBOL "circle"
>COLOR 128 255 164
>OUTLINECOLOR 12 200 100
>BACKGROUNDCOLOR 100 100 100
>SIZE 7
>END
>END
>LAYER
>NAME "crhran_wgs"
>#GROUP "hraniceCR_wgs"
>STATUS ON
>DATA "./hraniceCR_wgs/crhran_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "hranice_class"
>#SYMBOL "circle"
>COLOR 207 215 255
>OUTLINECOLOR 0 63 103
>END
>END
>LAYER
>NAME "obce_roz_wgs"
>#GROUP "Admin_wgs"
>STATUS ON
>DATA "./Admin_wgs/obce_roz_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "obce_roz_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "obce_pov_wgs"
>#GROUP "Admin_wgs"
>STATUS ON
>DATA "./Admin_wgs/obce_pov_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "obce_pov_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "obce_wgs"
>#GROUP "Admin_wgs"
>STATUS ON
>DATA "./Admin_wgs/obce_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "Zonace_CHKOJ_wgs"
>#GROUP "CHKO_wgs"
>STATUS ON
>DATA "./CHKO_wgs/Zonace_CHKOJ_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "Zonace_CHKOJ_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "mchu83_a_wgs"
>#GROUP "CHKO_wgs"
>STATUS ON
>DATA "./CHKO_wgs/mchu83_a_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "mchu83_a_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "MCHU_CHKOJ_wgs"
>#GROUP "CHKO_wgs"
>STATUS ON
>DATA "./CHKO_wgs/MCHU_CHKOJ_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "MCHU_CHKOJ_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "flouky_wgs"
>#GROUP "CHKO_wgs"
>STATUS ON
>DATA "./CHKO_wgs/flouky_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "flouky_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "branna_wgs"
>#GROUP "CHKO_wgs"
>STATUS ON
>DATA "./CHKO_wgs/branna_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "branna_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "HraniceCHKO_wgs"
>#GROUP "CHKO_wgs"
>STATUS ON
>DATA "./CHKO_wgs/HraniceCHKO_wgs"
>TYPE LINE
>UNITS METERS
>CLASS
>NAME "HraniceCHKO_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "rivers_poland_wgs"
>#GROUP "Povodi_wgs"
>STATUS ON
>DATA "./Povodi_wgs/rivers_poland_wgs"
>TYPE LINE
>UNITS METERS
>CLASS
>NAME "rivers_poland_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "povodi_bela_wgs"
>#GROUP "Povodi_wgs"
>STATUS ON
>DATA "./Povodi_wgs/povodi_bela_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "povodi_bela_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>LAYER
>NAME "jezera_pl_wgs"
>#GROUP "Povodi_wgs"
>STATUS ON
>DATA "./Povodi_wgs/jezera_pl_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "jezera_pl_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
># LAYER
>#NAME "bela_reka_wgs"
>#GROUP "Povodi_wgs"
>#STATUS ON
>#DATA "./Povodi_wgs/bela_reka_wgs"
>#TYPE LINE
>#UNITS METERS
>#CLASS
>#NAME "bela_reka_wgs_class"
>#COLOR 105 147 250
>#OUTLINECOLOR 0 0 0
>#END
>#END
>LAYER
>NAME "hranice_bela_wgs"
>#GROUP "Povodi_wgs"
>STATUS ON
>DATA "./Povodi_wgs/hranice_bela_wgs"
>TYPE POLYGON
>UNITS METERS
>CLASS
>NAME "hranice_bela_wgs_class"
>COLOR 105 147 250
>OUTLINECOLOR 0 0 0
>END
>END
>END
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
