[Mapserver-users] PROBLEM with GetFeatureInfo results???
Vincent Schut
schut at sarvision.com
Wed Aug 27 03:09:56 EDT 2003
On Tuesday 26 August 2003 18:07, Paul Spencer wrote:
> Josef, you will need to have a template attribute inside each layer
> object that you want to be queryable. It looks something like:
> TEMPLATE "ttt.html"
> The value "ttt.html" can be any non-empty value. Not sure if it must
> end in .html or not.
Nope, can be anything. I used 'template "dummy"' and all worked.
Cheers,
Vincent.
> Cheers,
> Paul
> Josef Stromský wrote:
> >Hi folks,
> >Im trying to getFeautreInfo from my MapServer, but Im unable to get some
> >results. My mapserv.exe returning this everytime :
> >GetFeatureInfo results:
> > Search returned no results.
> >My request URL is:
> >http://158.196.141.84/cgi-bin/mapserv.exe?map=D:/Apache/Apache/htdocs/Wgs8
> >4/transcat.map&REQUEST=GetFeatureInfo&VERSION=1.1.0&BBOX=12,47,19,52.25&SR
> >S=epsg:32633&WIDTH=800&HEIGHT=600&QUERY_LAYERS=CRhran_wgs&X=240&Y=242
> >Very similar getMap request works fine, but this is mystery for me. Maybe
> > is something missing here.
> >Thanks so much for any advice.
> >Here is my MapFile (it was createt from demo MapFile):
> ># Start of map file
> >MAP
> >NAME "TRANSCAT"
> >STATUS ON
> >EXTENT 12 48 18 51
> >SIZE 640 480
> >SHAPEPATH "."
> >IMAGECOLOR 255 255 255
> >UNITS METERS
> >IMAGETYPE PNG
> ># Start of web interface definition (including WMS enabling metadata)
> >WEB
> >MINSCALE 1000
> >MAXSCALE 1550000
> >IMAGEPATH "./tmp"
> >IMAGEURL "./tmp"
> >METADATA
> >"WMS_TITLE" "UMN MapServer Itasca Demo"
> >"WMS_ABSTRACT" "This is a UMN MapServer application for Itasca County
> >located in north central Minnesota."
> >"WMS_ACCESSCONSTRAINTS" "none"
> >"WMS_ONLINERESOURCE" "http://158.196.141.84/itasca/index.html"
> >"WMS_SRS" "epsg:32633"
> >END
> >END
> ># Start of reference map
> >REFERENCE
> >STATUS OFF
> >IMAGE "graphics/reference.png"
> >SIZE 120 120
> >EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
> >COLOR 255 0 0
> >OUTLINECOLOR 0 0 0
> >MINBOXSIZE 5
> >MAXBOXSIZE 100
> >MARKER "star"
> >MARKERSIZE 8
> >END
> ># Projection definition, consult the PROJ.4 documentation for parameter
> >discussion
> >PROJECTION
> ># \proj=utm\
> ># \ellps=GRS80\
> ># \zone=15\
> ># \north\
> ># \no_defs\
> ># OR:
> >"init=epsg:32633"
> >END
> ># Start of legend
> >LEGEND
> >STATUS ON
> >KEYSIZE 18 12
> >LABEL
> >TYPE BITMAP
> >SIZE MEDIUM
> >COLOR 0 0 89
> >END
> >END
> ># Start of scalebar
> >SCALEBAR
> >STATUS ON
> >COLOR 255 255 255
> >IMAGECOLOR 0 0 0
> >UNITS METERS
> >INTERVALS 1
> >SIZE 100 2
> >STYLE 1
> >LABEL
> >SIZE TINY
> >COLOR 255 255 255
> >END
> >END
> >#================================== Start of symbol definitions
> >SYMBOL
> >NAME "circle"
> >TYPE ELLIPSE
> >FILLED TRUE
> >POINTS
> >1 1
> >END
> >END
> >SYMBOL
> >NAME "star"
> >TYPE VECTOR
> >FILLED TRUE
> >POINTS
> >0 .375 .35 .375 .5 0 .65 .375 1 .375 .75 .625 .875 1 .5 .75 .125 1 .25
> > .625 END
> >END
> >#´======================================== Start of layer definitions
> >LAYER
> >NAME "useky_wgs"
> >#GROUP "silnicniDatabanka"
> >STATUS ON
> >DATA "./SilnicnidatabankaOstrava_wgs/useky_wgs"
> >TYPE LINE
> >CLASS
> >NAME "useky_class"
> >#SYMBOL "circle"
> >COLOR 0 0 0
> >SIZE 1
> >END
> >END
> >LAYER
> >NAME "uzly_wgs"
> >STATUS ON
> >DATA "./SilnicnidatabankaOstrava_wgs/uzly_wgs"
> >TYPE POINT
> ># OFFSITE 31
> >OFFSITE 252
> >METADATA
> >"WMS_TITLE" "Silniční databanka Ostrava"
> >"WMS_ABSTRACT" "Hibbing and Bemidji quadrangles. See
> >http://deli.dnr.state.mn.us/metadata/full/drgncim1.html for more
> >information."
> >END
> >CLASS
> >NAME "uzly_class"
> >SYMBOL "circle"
> >COLOR 128 255 164
> >OUTLINECOLOR 12 200 100
> >BACKGROUNDCOLOR 100 100 100
> >SIZE 7
> >END
> >END
> >LAYER
> >NAME "crhran_wgs"
> >#GROUP "hraniceCR_wgs"
> >STATUS ON
> >DATA "./hraniceCR_wgs/crhran_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "hranice_class"
> >#SYMBOL "circle"
> >COLOR 207 215 255
> >OUTLINECOLOR 0 63 103
> >END
> >END
> >LAYER
> >NAME "obce_roz_wgs"
> >#GROUP "Admin_wgs"
> >STATUS ON
> >DATA "./Admin_wgs/obce_roz_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "obce_roz_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "obce_pov_wgs"
> >#GROUP "Admin_wgs"
> >STATUS ON
> >DATA "./Admin_wgs/obce_pov_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "obce_pov_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "obce_wgs"
> >#GROUP "Admin_wgs"
> >STATUS ON
> >DATA "./Admin_wgs/obce_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "Zonace_CHKOJ_wgs"
> >#GROUP "CHKO_wgs"
> >STATUS ON
> >DATA "./CHKO_wgs/Zonace_CHKOJ_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "Zonace_CHKOJ_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "mchu83_a_wgs"
> >#GROUP "CHKO_wgs"
> >STATUS ON
> >DATA "./CHKO_wgs/mchu83_a_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "mchu83_a_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "MCHU_CHKOJ_wgs"
> >#GROUP "CHKO_wgs"
> >STATUS ON
> >DATA "./CHKO_wgs/MCHU_CHKOJ_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "MCHU_CHKOJ_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "flouky_wgs"
> >#GROUP "CHKO_wgs"
> >STATUS ON
> >DATA "./CHKO_wgs/flouky_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "flouky_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "branna_wgs"
> >#GROUP "CHKO_wgs"
> >STATUS ON
> >DATA "./CHKO_wgs/branna_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "branna_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "HraniceCHKO_wgs"
> >#GROUP "CHKO_wgs"
> >STATUS ON
> >DATA "./CHKO_wgs/HraniceCHKO_wgs"
> >TYPE LINE
> >UNITS METERS
> >CLASS
> >NAME "HraniceCHKO_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "rivers_poland_wgs"
> >#GROUP "Povodi_wgs"
> >STATUS ON
> >DATA "./Povodi_wgs/rivers_poland_wgs"
> >TYPE LINE
> >UNITS METERS
> >CLASS
> >NAME "rivers_poland_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "povodi_bela_wgs"
> >#GROUP "Povodi_wgs"
> >STATUS ON
> >DATA "./Povodi_wgs/povodi_bela_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "povodi_bela_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >LAYER
> >NAME "jezera_pl_wgs"
> >#GROUP "Povodi_wgs"
> >STATUS ON
> >DATA "./Povodi_wgs/jezera_pl_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "jezera_pl_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> ># LAYER
> >#NAME "bela_reka_wgs"
> >#GROUP "Povodi_wgs"
> >#STATUS ON
> >#DATA "./Povodi_wgs/bela_reka_wgs"
> >#TYPE LINE
> >#UNITS METERS
> >#CLASS
> >#NAME "bela_reka_wgs_class"
> >#COLOR 105 147 250
> >#OUTLINECOLOR 0 0 0
> >#END
> >#END
> >LAYER
> >NAME "hranice_bela_wgs"
> >#GROUP "Povodi_wgs"
> >STATUS ON
> >DATA "./Povodi_wgs/hranice_bela_wgs"
> >TYPE POLYGON
> >UNITS METERS
> >CLASS
> >NAME "hranice_bela_wgs_class"
> >COLOR 105 147 250
> >OUTLINECOLOR 0 0 0
> >END
> >END
> >END
> >_______________________________________________
> >Mapserver-users mailing list
> >Mapserver-users at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
