[Mapserver-users] mapscript - queryByPoint help, simple Q
Eric Bridger
eric at gomoos.org
Thu Aug 28 09:32:46 EDT 2003
$layerObj = @$map->queryByPoint ($ptClicked, ms_single, 1000);
The above is wrong. That sets $layerObj to MS_SUCCESS, but you still
need the LayerObject for:
$results = $layerObject->{results};
etc.
On Thu, 2003-08-28 at 16:28, jose.quintal at cfe.gob.mx wrote:
> I follow without being able to make the Querybypoint to layer dynamic
> I have inside the loop
> if($layerObj->addFeature($shp) == -1)
> { echo "addFeature failed";
> is this the loop
> while($reg=mysql_fetch_array($p))
> $a=$reg['id'];
> $b=$reg['cor_x'];
> $c=$reg['cor_y'];
> //set the X Y values of the point object
> $pointObj->setXY($b,$c);
> $line = ms_newLineObj();
> $line ->add($pointObj);
> $shp = ms_newShapeObj(MS_SHAPE_POINT);
> $shp->add($line);
> //$shp->setBounds();
> $shp->{text} = $a;
> $shp->{index} = $i;
> if($layerObj->addFeature($shp) == -1){
> $point_lookup[$i] = $a;
> $i++;
> $pointObj->draw($map, $layerObj, $image, 0, $a);
> and the Querybypoint asi I put it:
> $layerObj = @$map->queryByPoint ($ptClicked, ms_single, 1000); It returns
> perfect MS_SUCCESS,
> but
> // this is an index into the point lookup table.
> $record = $rslt->{shapeindex};
> It returns to me -1
> Why?
> José Antonio Quintal Castillo
> Sistemas
> Tel 9243128 O 9243136
