[Mapserver-users] Unique? Was: mapscript - queryByPoint help, simple Q
poff
poff at sixbit.org
Fri Aug 29 23:44:41 EDT 2003
Hello
I didn't, but that didn't help.
The point is selected, it just doesn't show the shape data.
The whole thing is in a new post - $shp->{resultscache}
Thanks!
P
On Fri, Aug 29, 2003 at 05:37:18PM -0400, woodbri at swoodbridge.com wrote:
> poff,
> Do you have TOLERANCE set to a value, if it defaults to 0.0 then it
> is going to be pretty hard to selecet a point.
> -Steve
> On 29 Aug 2003 at 14:08, poff wrote:
> > Hello
> > I know everyone is busy - and thanks a lot for your help.
> > Only, does _no-one_ use querbypoint with php mapscript?
> > It's a great feature if I could get it working, and definitely
> > something to go in Wiki someday!
> > Thanks
> > P
> > On Thu, Aug 28, 2003 at 11:40:42PM +0200, poff wrote:
> > > > The problem is probably in your map file.
> > > > TEMPLATE belongs in the LAYER not the CLASS.
> > > Thanks, I changed this and no change to the outcome.
> > > However, I added the TEMPLATE tag to all of the layers and then
> > > suddenly, on the last layer:
> > > Warning: MapServer Error in msOpenSHPFile(): No (NULL) filename
> > > provided
> > > This is using $mapObj->query...
> > > With the $uLayer->query it just says no records.
> > > Then when I changed $uLayer to the last one they both give the NULL
> > > error.
> > > I'll go bald with all this hair pulling out!
> > > Thanks,
> > > P
> > > > On Thu, 2003-08-28 at 19:15, poff wrote:
> > > > > Hello again
> > > > > I've tried all the list suggestions with the followig code, but
> > > > > am _still_ getting "No Records Found".
> > > > > If anyone could suggest or point out what I'm doing wrong I'd be
> > > > > greatly indebted to them!
> > > > > Here it goes:
> > > > > $map = ms_newMapObj($mapfile);
> > > > > $uLayer = $map->getLayerByName("Points");
> > > > > $uLayer->set("status",1);
> > > > > $image=$map->draw();
> > > > > while () {
> > > > > $oPoint = ms_newPointObj();
> > > > > $oPoint->setXY($geoData['px'], $geoData['py']);
> > > > > $line = ms_newLineObj();
> > > > > $line->add($oPoint);
> > > > > $shp=ms_newShapeObj(MS_SHAPE_POINT);
> > > > > $shp->add($line);
> > > > > $shp->{text}=$geoData['place_name'];
> > > > > $shp->{index}=$i;
> > > > > $uLayer->addFeature($shp);
> > > > > $oPoint->draw($map, $uLayer, $image, 0,
> > > > > $geoData['place_name']);
> > > > > $my_point = ms_newpointObj();
> > > > > $my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]);
> > > > > $map->queryByPoint($my_point, MS_SINGLE, 20);
> > > > > $uLayer->queryByPoint($my_point,MS_SINGLE,-10); // for good
> > > > > measure ...
> > > > > And the mapfile:
> > > > > LAYER
> > > > > NAME "Points"
> > > > > STATUS ON
> > > > > TYPE POINT
> > > > > LABELCACHE FALSE
> > > > > CLASS
> > > > > NAME "User Marker"
> > > > > SYMBOL "marker"
> > > > > TEMPLATE "dummy"
> > > > > LABEL
> > > > > END
> > > > > END
> > > > > END
> > > > > I'm pretty stumped! I tried by $map-> and $Layer-> queryByPoint
> > > > > to no great joy.
> > > > > Thanks in advance,
> > > > > P
> > > > > poff at sixbit.org
> > > > > SDF Public Access UNIX System - http://sdf.lonestar.org
> > > > > Please do not carbon copy replies to me
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> > > > > Mapserver-users at lists.gis.umn.edu
> > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > poff at sixbit.org
> > poff at sixbit.org
poff at sixbit.org
