[Mapserver-users] SDE point query with version 4.0
Liz Godwin
godwinl at agr.gc.ca
Thu Aug 28 15:00:02 EDT 2003
Hello,
I'm trying to upgrade a simple application to the new version of
Mapserver (4.0) and I am running into an error I haven't seen before,
and haven't been able to sort out.
"msSDELayerWhichShapes(): SDE error. SE_shape_generate_rectangle(): The
number of points is less than required for feature. (-148)"
I get the same error with or without my template file. My mapfile is
referencing only SDE layers. The error only occurs when I am trying to
query a layer, not when I'm just navigating around the map.
The application queries fine if I point to Mapserver 3.6 instead.
Has anyone had any luck in upgrading sites using SDE that might have a
clue into where I should poke? Thanks!!
Liz Godwin
