[Mapserver-users] How to ignore a non-existent layer?
Puneet Kishor
pkishor at geoanalytics.com
Thu Aug 28 22:28:26 EDT 2003
On Thursday, August 28, 2003, at 09:00 PM, Daniel Morissette wrote:
> pkishor_98 wrote:
>> I have a mapfile with a bunch of layers and their classes defined. I
>> want MapServer to NOT croak if a layer defined in the mapfile doesn't
>> exist... just silently ignore it. Is there a way to do that?
> If you define "-DIGNORE_MISSING_DATA" at compile time then MapServer
> will silently ignore layers pointing to non existing shapefiles.
> On Unix/Linux (all platforms using the configure script), this is
> enabled by default and you can force MapServer to be strict using
> --disable-ignore-missing-data in your configure options.
> On Winows I think the default Makefile doesn't include this option by
> default and you have to explicitly add -DIGNORE_MISSING_DATA to the
> compile flags.
Thanks... that's good to know.
Is it possible to enable MapServer so this option can be specified at
run-time instead of compile time... like, say... by setting a value in
the mapfile or through Mapscript via some exported method from the
module...
Now, that would be nice.
