[Mapserver-users] Unique? Was: mapscript - queryByPoint help,
simple Q
Lowther, David W
dlowther at ou.edu
Fri Aug 29 10:45:31 EDT 2003
That's where my code began - Gmap. Couldn't remember...
<?php
GLOBAL $gpoMap, $gbShowQueryResults;
$map_path = "e:\map.map";
$gpoMap = ms_newMapObj($map_path);
'I'm submitting a form that has x, y, mapext, and mapsize...
$click_x = $_POST["x"];
$click_y = $_POST["y"];
$me = $_POST["mapext"];
$mapsize = $_POST["mapsize"];
$msArray = explode(" ", $mapsize);
$mapwidth = $msArray[0];
$mapheight = $msArray[1];
$current_extent = explode(" ",$me);
$x_pct = ($click_x / $mapwidth);
$y_pct = 1 - ($click_y / $mapheight);
$nClickGeoX = $current_extent[0] + ( ($current_extent[2] -
$current_extent[0]) * $x_pct);
$nClickGeoY = $current_extent[1] + ( ($current_extent[3] -
$current_extent[1]) * $y_pct);
'// I have to do this because my mapfile is projected to albers, but
my shapefiles are lat lon...
$extRect = ms_newRectObj();
$extRect->SetExtent($nClickGeoX,$nClickGeoY,$nClickGeoX+0.0001,$nClickGeoY+0
.0001);
$oClickGeo = ms_newPointObj();
$oClickGeo->setXY($extRect->minx,$extRect->miny);
$projOutObj = ms_newprojectionobj("proj=latlong,ellps=GRS80");
$projInObj =
ms_newprojectionobj("proj=aea,ellps=GRS80,datum=NAD83,lat_0=23,lon_0=-96,lat
_1=29.5,lat_2=45.5,x_0=0,y_0=0");
$newRect = $extRect->project($projInObj, $projOutObj);
print "<form method=post name=results action=something>\n";
print "<input type=hidden name=LAT value=".$extRect->miny.">\n";
print "<input type=hidden name=LON value=".$extRect->minx.">\n";
// Use '@' to avoid warning if query found nothing
$oLayer = $gpoMap->GetLayerByName("huc8");
$oLayer->set("status",MS_ON);
@$gpoMap->queryByPoint($oClickGeo, MS_MULTIPLE, 20);
$gbShowQueryResults = TRUE;
if (! $gbShowQueryResults )
printf(" ");
return;
$numResultsTotal = 0;
for($iLayer=0; $iLayer < $gpoMap->numlayers; $iLayer++)
$oLayer = $gpoMap->GetLayer($iLayer);
$numResults = $oLayer->getNumResults();
if ($numResults == 0)
continue; // No results in this layer
$oLayer->open();
'//this only writes data for the fields in each layers metadata
"RESULT_FIELDS"
$selFields = explode(" ", $oLayer->getMetaData("RESULT_FIELDS"));
for ($iRes=0; $iRes < $numResults; $iRes++)
$oRes = $oLayer->getResult($iRes);
$oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
for($iField=0; $iField < sizeof($selFields); $iField++)
name=".$selFields[$iField]."
value=\"".$oShape->values[$selFields[$iField]]."\">\n";
$oShape->free();
$numResultsTotal++;
$oLayer->close();
print "</form>\n";
Heres the Layer in the mapfile...
### HUC8 ###
LAYER
NAME huc8
GROUP "Bio Survey"
TYPE LINE
STATUS OFF
DATA watershd_dd
PROJECTION #GEOGRAPHIC NAD83
proj=longlat
ellps=GRS80
no_defs
END
TRANSPARENCY 70
TEMPLATE "IDHUC8.htm"
CLASS#
NAME "Watersheds"
COLOR 0 0 0
END
METADATA
"RESULT_FIELDS" "HUC"
"wms_group_title" "BioSurvey"
"wms_title" "Watersheds"
legend_order "10"
END
END
Here's the template - although it doesn't affect the results here - unless
it doesn't exist...
<html>
<body>
<table align=center valign=top width=95% border=0 celpadding=0 cellspacing=0
class=key_background>
<tr ><td align=center class=key_header colspan=2>Identify
Results</td></tr>
<tr><td align=center colspan=2><b>HUC:</b> [HUC]<br></td></tr>
<tr><td>Region: [REGION]</td><td>Subregion: [SUBREGION]</td></tr>
<tr><td>Acctunit: [ACCTUNIT]</td><td>Hydrounit:
[HYDROUNIT]</td></tr>
<tr><td>Proper Name: [PROPER_NAM]</td><td>Main River:
[MAIN_RIVER]</td></tr>
<tr><td colspan=2 align=center>Loc Desc: [LOCATION_D]</td></tr>
</table>
</body>
</html>
> -----Original Message-----
> From: Eric Bridger [mailto:eric at gomoos.org]
> Sent: Friday, August 29, 2003 4:50 AM
> To: poff
> Cc: Mapserver List
> Subject: Re: [Mapserver-users] Unique? Was: mapscript -
> queryByPoint help, simple Q
> Sorry you're having so much trouble. I do perl mapscript
> queryByPoint extensively. Have you tried looking att the
> GMap PHP demo php source? It will show you how to do
> everything with PHP mapscript.
> http://www2.dmsolutions.ca/gmap/gmap75.phtml
> E.g the following code is wrong:
> > $my_point = ms_newpointObj();
> > $my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]
> $_REQUEST["mapa_x"] and "mapa_y" are the pixel coordinates of
> your mouse click. You need to first transform them to
> geographic coordinates. The gmap75.php file contains a
> function: GMapPix2Geo() which does this.
> Here's a perl example:
> sub get_click {
> my ($q, $map) = @_;
> my @current_extent = ();
> my($x_map, $y_map) = (0,0);
> if($q->param('img.x') && $q->param('imgext')) { # Make
> sure we got a click
> @current_extent = split(' ', $q->param('imgext'));
> my $click_x = $q->param('img.x');
> my $click_y = $q->param('img.y');
> my $x_pct = ($click_x / $map->{width});
> my $y_pct = 1 - ($click_y / $map->{height});
> $x_map = $current_extent[0] + ( ($current_extent[2] -
> $y_map = $current_extent[1] + ( ($current_extent[3] -
> return ($x_map, $y_map);
> On Fri, 2003-08-29 at 12:08, poff wrote:
> > Hello
> > I know everyone is busy - and thanks a lot for your help.
> > Only, does _no-one_ use querbypoint with php mapscript?
> > It's a great feature if I could get it working, and definitely
> > something to
> > go in Wiki someday!
> > Thanks
> > P
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
