[Mapserver-users] Nearly there! "Inline shapes" Was: Unique? Was: mapscript - queryByPoint help, simple Q
poff
poff at sixbit.org
Fri Aug 29 12:51:10 EDT 2003
Hello All,
Thanks for your help, I've been making progress!
Basically I now get results with queryByPoint, it's getting at them which
is puzzling me (different question now).
I have a layer with points drawn from a database, such as:
$line = ms_newLineObj();
$line->add($oPoint);
$shp=ms_newShapeObj(MS_SHAPE_POINT);
$shp->add($line);
$shp->{text}="hll";
$shp->{index}="99";
$uLayer->addFeature($shp);
The ulayer has no data, just a symbol for each point.
Now I have a problem when I get the shapefile back from the results:
$uLayer->open($map->shapepath);
$oRes=$uLayer->getResult(0);
// this next bit gives an error
$oShape = $uLayer->getShape($oRes->tileindex,$oRes->shapeindex);
"Error in msLayerGetShape(): Cannot retrieve inline shapes randomly."
However if I use another layer, the layer with all the shapedata, I get a
lovely array with all the shapefile data, built into the shapefile.
Corresponding to the click.
If I do
addFeature($shp) to the main layer, it gives me the same error. It seems
whatever layer I addFeature to it gives the error.
Only, I need to get at the $shp data above (I really need the $shp->{index}
part to get back the data from the database);
Do you have any ideas?
It's so close! I can almost taste that index ;)
Again a BIG thank you for helping me so far.
P
On Fri, Aug 29, 2003 at
09:50:10AM +0000, Eric Bridger wrote:
> Sorry you're having so much trouble. I do perl mapscript queryByPoint
> extensively. Have you tried looking att the GMap PHP demo php source?
> It will show you how to do everything with PHP mapscript.
> http://www2.dmsolutions.ca/gmap/gmap75.phtml
> E.g the following code is wrong:
> > $my_point = ms_newpointObj();
> > $my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]
> $_REQUEST["mapa_x"] and "mapa_y" are the pixel coordinates of your mouse
> click. You need to first transform them to geographic coordinates. The
> gmap75.php file contains a function: GMapPix2Geo() which does this.
> Here's a perl example:
> sub get_click {
> my ($q, $map) = @_;
> my @current_extent = ();
> my($x_map, $y_map) = (0,0);
> if($q->param('img.x') && $q->param('imgext')) { # Make sure we got a
> click
> @current_extent = split(' ', $q->param('imgext'));
> my $click_x = $q->param('img.x');
> my $click_y = $q->param('img.y');
> my $x_pct = ($click_x / $map->{width});
> my $y_pct = 1 - ($click_y / $map->{height});
> $x_map = $current_extent[0] + ( ($current_extent[2] -
> $current_extent[0]) * $x_pct);
> $y_map = $current_extent[1] + ( ($current_extent[3] -
> $current_extent[1]) * $y_pct);
> return ($x_map, $y_map);
> On Fri, 2003-08-29 at 12:08, poff wrote:
> > Hello
> > I know everyone is busy - and thanks a lot for your help.
> > Only, does _no-one_ use querbypoint with php mapscript?
> > It's a great feature if I could get it working, and definitely something to
> > go in Wiki someday!
> > Thanks
> > P
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
poff at sixbit.org
SDF Public Access UNIX System - http://sdf.lonestar.org
Please do not carbon copy replies to me
