[Mapserver-users] Nearly there! "Inline shapes" Was: Unique? Was: mapscript - queryByPoint help, simple Q
poff
poff at sixbit.org
Fri Aug 29 14:12:47 EDT 2003
Hello,
Thanks again - but I get the result to be -1 this time.
I'm getting the same as my last post:
[shapeindex] => -1 [tileindex] => -1 [classindex] => 0
LAYER
NAME "uLayer"
STATUS ON
TYPE POINT
TEMPLATE "dummy"
CLASS
NAME "User Marker"
SYMBOL "marker"
END
END
$line = ms_newLineObj();
$line->add($oPoint);
$shp=ms_newShapeObj(MS_SHAPE_POINT);
$shp->add($line);
$shp->{text}="hll";
$shp->{index}=99;
$uLayer->addFeature($shp);
$uLayer->queryByPoint($my_point, MS_SINGLE, 20);
//$uLayer->getNumResults() = 1
$results = $uLayer->{resultcache};
// above is empty, returns -1 for:
$rslt = $uLayer->getResult(0);
$database_id = $rslt->{shapeindex};
Many thanks,
P
On Fri, Aug 29, 2003 at 01:39:09PM +0000, Eric Bridger wrote:
> You don't have a shapefile for this layer. You created the layer from a
> database of points. You get the shapeindex from the results in the
> resultcache.
> So all you should need to do is: (once again in perl but easily adpated
> to PHP.
> if($uLayer->queryByPoint($map,$click_pt,$mapscript::MS_SINGLE,0) ==
> MS_SUCCESS){
> my $results = $uLayer->{resultcache};
> # we only expect one result.
> my $rslt = $uLayer->getResult(0);
> my $database_id = $rslt->{shapeindex};
> On Fri, 2003-08-29 at 16:51, poff wrote:
> > Hello All,
> > Thanks for your help, I've been making progress!
> > Basically I now get results with queryByPoint, it's getting at them which
> > is puzzling me (different question now).
> > I have a layer with points drawn from a database, such as:
> > $shp->add($line);
> > $shp->{text}="hll";
> > $shp->{index}="99";
> > The ulayer has no data, just a symbol for each point.
> > Now I have a problem when I get the shapefile back from the results:
> > $uLayer->open($map->shapepath);
> > $oRes=$uLayer->getResult(0);
> > // this next bit gives an error
> > $oShape = $uLayer->getShape($oRes->tileindex,$oRes->shapeindex);
> > "Error in msLayerGetShape(): Cannot retrieve inline shapes randomly."
> > However if I use another layer, the layer with all the shapedata, I get a
> > lovely array with all the shapefile data, built into the shapefile.
> > Corresponding to the click.
> > If I do
> > addFeature($shp) to the main layer, it gives me the same error. It seems
> > whatever layer I addFeature to it gives the error.
> > Only, I need to get at the $shp data above (I really need the $shp->{index}
> > part to get back the data from the database);
> > Do you have any ideas?
> > It's so close! I can almost taste that index ;)
> > Again a BIG thank you for helping me so far.
> > P
> > 09:50:10AM +0000, Eric Bridger wrote:
> > > Sorry you're having so much trouble. I do perl mapscript queryByPoint
> > > extensively. Have you tried looking att the GMap PHP demo php source?
> > > It will show you how to do everything with PHP mapscript.
> > > http://www2.dmsolutions.ca/gmap/gmap75.phtml
> > > E.g the following code is wrong:
> > > > $my_point = ms_newpointObj();
> > > > $my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]
> > > $_REQUEST["mapa_x"] and "mapa_y" are the pixel coordinates of your mouse
> > > click. You need to first transform them to geographic coordinates. The
> > > gmap75.php file contains a function: GMapPix2Geo() which does this.
> > > Here's a perl example:
> > > sub get_click {
> > > my ($q, $map) = @_;
> > > my @current_extent = ();
> > > my($x_map, $y_map) = (0,0);
> > > if($q->param('img.x') && $q->param('imgext')) { # Make sure we got a
> > > click
> > > @current_extent = split(' ', $q->param('imgext'));
> > > my $click_x = $q->param('img.x');
> > > my $click_y = $q->param('img.y');
> > > my $x_pct = ($click_x / $map->{width});
> > > my $y_pct = 1 - ($click_y / $map->{height});
> > > $x_map = $current_extent[0] + ( ($current_extent[2] -
> > > $current_extent[0]) * $x_pct);
> > > $y_map = $current_extent[1] + ( ($current_extent[3] -
> > > $current_extent[1]) * $y_pct);
> > > return ($x_map, $y_map);
> > > On Fri, 2003-08-29 at 12:08, poff wrote:
> > > > Hello
> > > > I know everyone is busy - and thanks a lot for your help.
> > > > Only, does _no-one_ use querbypoint with php mapscript?
> > > > It's a great feature if I could get it working, and definitely something to
> > > > go in Wiki someday!
> > > > Thanks
> > > > P
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > poff at sixbit.org
> > SDF Public Access UNIX System - http://sdf.lonestar.org
> > Please do not carbon copy replies to me
poff at sixbit.org
