[Mapserver-users] GeoTiff's
Andy Green
green at fboweb.com
Tue Dec 2 09:59:47 EST 2003
Ok, I've done that (renamed it from .tfw to .wld), but I'm still running
into trouble with the map not being in the location it should be, which
makes me think there COULD be a problem with the projection...
But the .TIF is in the LCC projection, and it's the only layer in the
map, so I've set the map's projection to be LCC as well. Shouldn't that
solve my problems as far as reprojection is concerned?
Andy, green at fboweb.com
PS: Thanks for responding...! So far at this point, ANY help is
greatly appreciated! :-)
-----Original Message-----
Sent: Tuesday, December 02, 2003 9:34 AM
To: Andy Green; 'Mapserver List'
Subject: Re: [Mapserver-users] GeoTiff's
In the past we have had to rename the tfw's to wld for it to work.
This assumes there is no reprojection required.
Lowell
The following message was sent by "Andy Green" <green at fboweb.com> on
Mon, 1 Dec 2003 23:45:44 -0500.
> I have a Geotiff layer. it's called Sample.tif. The vendor provided a
> .TFW file, called sample.tfw.
> Do I have to do anything special to get the Mapserver to recognize the
> .tfw file? Do I have to rename it to sample.wld?
> How does that all work?
