[Mapserver-users] 4.0 JOIN problem
AJackson at realtors.org
Thu Dec 4 17:58:58 EST 2003
I'm trying to use the JOIN object with MapServer 4.0.1 When I use the mapfile below,
I get the error
loadClass(): Unknown Identifier. Parsing error near (JOIN):(line ...)
If I take the JOIN object out of the class, and put it into the LAYER, I avoid the
error but the template is not called. The join does appear to be executed,
since I can generate rate a "DBASE file error" by putting in a false field name
in either "TO" or "FROM". Any suggestions? Better yet, any working examples?
LAYER
NAME "state_sel2"
TYPE QUERY
STATUS DEFAULT
DATA "st_combined"
FILTER "%SELECTED_STATE%"
FILTERITEM 'STATE'
CLASS
NAME "sthistory"
TEMPLATE "empty.html"
JOIN
NAME "state_history"
TABLE "/var/www/html/maps/data/us_st_avg.dbf"
TYPE SINGLE
FROM "STYPE"
TO "HTYPE"
TEMPLATE "ImpactTemplates/historic_data.html"
END
END
END
