[Mapserver-users] problem with Layer on-fly with MapServer 4
Andrés Collao
collao_andres at hotmail.com
Sat Dec 6 14:51:58 EST 2003
thank you, right now, i know the problem
the mapfile don´t have de following porperties:
color
connectiontype
size
(these are the properties that I could prove)
when i try use STYLE object this don't work , why? i don't know, but reading
the /tmp/test.map i see I could observe that the properties for color, size
were not written this also happen to CONNECTIONTYPE, when trying to form it
dynamically, simply do not make
solution?
creates a layer with those values in mapfile that I cannot form of dynamic
form. if somebody can create to layer of dynamic form, please, tell me or
writes the solution in this page
::: Andrés Collao Pérez :::
[ collao_andres at hotmail.com ]
[ andres at mapserver.cl ]
:::El hombre es un Dios cuando sueña y un mendigo cuando reflexiona.
:::Il peggior nemico del succeso è la pauta del fallimiento
:::El peor enemigo del éxito es el miedo al fracaso
thank's
----Original Message Follows----
From: Daniel Morissette <morissette at dmsolutions.ca>
To: collao_andres <collao_andres at hotmail.com>
CC: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] problem with Layer on-fly with MapServer 4
Date: Sat, 06 Dec 2003 13:40:06 -0500
collao_andres wrote:
>hi, i have the following code in PHP/MapScript
>dl('php_mapscript.so');
>// Default values and configuration
>$gpoMap_path="/usr/local/apache2/htdocs/test/data/";
>$gpoMap = ms_newMapObj($gpoMap_path."base.map");
>$layer_tmp=ms_newLayerObj($gpoMap);
>$layer_tmp->set('name','cuencas');
>$layer_tmp->set('status',MS_On);
Constant names are case-sensitive. You should use MS_ON in the line above.
If your layer still doesn't show up after that change then try doing a
$gpoMap->save("/tmp/test.map") just before your draw() call and then check
that the layer definition in the saved mapfile looks the way you expect.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
_________________________________________________________________
Charla con tus amigos en línea mediante MSN Messenger:
http://messenger.latam.msn.com/
