[Mapserver-users] problem with Layer on-fly with MapServer 4
Daniel Morissette
morissette at dmsolutions.ca
Mon Dec 8 10:25:25 EST 2003
Andrés Collao wrote:
> thank you, right now, i know the problem
> the mapfile don´t have de following porperties:
> color
> connectiontype
> size
> (these are the properties that I could prove)
> when i try use STYLE object this don't work , why? i don't know, but
> reading the /tmp/test.map i see I could observe that the properties for
> color, size were not written this also happen to CONNECTIONTYPE, when
> trying to form it dynamically, simply do not make
About the POSTGIS problem, your code contained the line:
$layer_tmp->set('connectiontype',POSTGIS);
The constant for connection type POSTGIS is MS_POSTGIS and not POSTGIS.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
