[Mapserver-users] Hard-coded path to the Proj directory
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 11 16:56:05 EST 2003
A P wrote:
> Hi,
> I'm using a precompiled (for windows) MapServer cgi 4.0. I've realized
> that I cannot put my "Proj" folder immediately under C (that is,
> C:/Proj). Since this seems to be one of the requirements on the
> MapServer, I don't think it will work.
> How could I manage this? Do I have to compile MapServer myself, or is it
> possible to do some configuration stuff?
> I've tried to understand how to compile it, but I reall can't make it.
> Has anyone done exactly what i want to do: use MapServer as is except
> for the hard-coded path to the Proj directory?
Anders,
You can recompile the PROJ.DLL with a different path, or you can set
the PROJ_LIB environment variable to point to an alternate directory.
I would like to make it so you can set this from within a map file, but
haven't gotten around to that.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
