ENC: Re: [Mapserver-users] Shape Index ...
Lowell Filak
lfilak at medinaco.org
Fri Dec 12 15:48:50 EST 2003
I think the purpose of $map->querybypoint is to "allow" you to query All
layers at once.
If you need to query a single layer why not use $layer->querybypoint
instead?
Otherwise wouldn't the loop for the layers have always existed vs.
"changed for another".?
Lowell
The following message was sent by "Murilo Lacerda Yoshida"
<murilo.yoshida at agx.com.br> on Fri, 12 Dec 2003 17:38:25 -0200.
> -----Mensagem original-----
> De: Murilo Lacerda Yoshida [mailto:murilo.yoshida at agx.com.br]
> Enviada em: sexta-feira, 12 de dezembro de 2003 17:38
> Para: 'Lowell Filak'
> Assunto: RES: Re: [Mapserver-users] Shape Index ...
> Thanks, it worked. However, I changed a loop for another... Because
> before I was doing $map->querybypoint and now I have to make a loop in
> all the layers... Unless there is a way to do this without this loop,
> but I don't see how.
> Thanks again,
> Murilo
> De: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] Em nome de Lowell Filak
> Enviada em: sexta-feira, 12 de dezembro de 2003 16:15
> Para: mapserver-users at lists.gis.umn.edu
> Assunto: Fwd: Re: [Mapserver-users] Shape Index ...
> Allow me to expand on my previous post - hopefully this will clear it
> up.
> The shape index is part of the result member and must be accessed
> through the query result which is held in the layer - it is not returned
> as part of the query method.
> $result = $layer->queryByPoint($map,$point,$mapscript::MS_SINGLE,0);
> $resultcachemember = $layer->getResult(0);
> $polyshapeindex = $resultcachemember->{shapeindex};
> Lowell
> The following message was sent by "Lowell Filak"<lfilak at medinaco.org> on
> Thu, 11 Dec 2003 15:36:01 -0500.
> > In MapScript the method & members are:
> > queryByPoint
> > resultcache
> > getResult
> > shapeindex
> > Is that what your looking for?
> > Lowell
> > <murilo.yoshida at agx.com.br> on Thu, 11 Dec 2003 18:18:52 -0200.
> > > Hi All,
> > > Is there a function that you pass a point(x, y) and it returns you
> the
> > > index of the shape you've clicked?
> > > Thanks,
> > > Murilo
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
