[Mapserver-users] FW: Almost ok !
Swaminathan, Gayathri
gayathri at ou.edu
Tue Dec 16 09:25:49 EST 2003
-----Original Message-----
From: Ballini Yvain [mailto:Ballini.Yvain at seat.it]
Sent: Tuesday, December 16, 2003 3:02 AM
To: Swaminathan, Gayathri
Subject: Almost ok !
Thank you first for your help! Changing all the path and some option in my
nmake.opt, I've recompiled mapserver with your gdal. Now when I run the
mapserver.exe, it turns me the CGI error during the demo_init :
The specified CGI application misbehaved by not returning a complete set of
HTTP headers. The headers it did return are:
And in fact, if I run the command mapservev -v in the directory where I put
the mapserv.exe (..\Inetpub\Scripts), it turns me that it can't run the
application because it's looking for gdal11.dll. I wonder if the problem is
that I link your gdal dynamically and not statically. Has you got any idea?
Thank you again, it's very nice to help me ! :) Yvain.
-----Messaggio originale-----
Da: Swaminathan, Gayathri [mailto:gayathri at ou.edu]
Inviato: lunedì 15 dicembre 2003 19.15
A: Ballini Yvain
Oggetto: RE:
Yvain:
Also check all the other files in gdal stuff for such paths... I changes
quite a few to look in e: drive if I remember correctly...
As you see below the rest all is warnings...so it should not break because
of those.
One other thing is "don't rebuild gdal" as I have already compiled it...
Copy that gdal11.dll to the windows system directory and register it.
Now compile mapserver again...make clean before make....
Let me know how goes it
Thanks
Sent: Monday, December 15, 2003 10:31 AM
Subject: R: That would be all
Ok, this is some problem with your gdal.h which use the absolute path (line
126) #include "e:\mapserver4\gdal\port\cpl_port.h"
#include "e:\mapserver4\gdal\port\cpl_error.h"
When I put the mine, save the gdal.h and try to recompile gdal, it turns
some similar error:
NMAKE: fatal error U1077: 'cd' :return code '0x1'.
I've also noticed that your cpl.lib is bigger (164 KB) than the mine (76 KB)
but I can't use it directly, unless it turns me many errors like these one:
ogr.lib(swq.obj) : warning LNK4217: locally defined symbol _strncat imported
in function _swq_subexpr_compile
OLDNAMES.lib(stricmp.obi) : warning LNK4049: locally defined symbol
__stricmp im ported
OLDNAMES.lib(strnicmp.obi) : warning LNK4049: locally defined symbol
__strnicmp imported mapserv.exe : fatal error LNK1169: one or more multiply
defined symbols found NMAKE : fatal error U1077: 'link' : return code
'0x491' Stop.
Has you any idea of the matter?
Thanks again.
Yvain.
Inviato: lunedì 15 dicembre 2003 16.56
A: Ballini Yvain
Oggetto: That would be all
Yvain:
That would be all of my compiled gdal
You should have a
Gdal1.zip
Gdal2.zip
Gdal3-a_1.zip
Gdal3-a_2.zip
Gdal4-a.zip
Gdal4-b.zip
Gdal4-c.zip
Gdal4-d.zip
Let me know if you need further help
Thanks
