[Mapserver-users] rendering of shapefile not correct?
bartvde at xs4all.nl
Wed Dec 17 06:34:55 EST 2003
Hi list,
I have a problem with Mapserver not rendering a shapefile correctly. Some
parts of lines are disappearing, but these are always the same parts.
I have put 3 images on our webserver to illustrate this problem. It is a
map of the Dutch counties, but the line areas which are "broken" (i.e.
discontinuous) are in fact also broken in the shapefile, but just for a
very small distance. In the Mapserver image this broken part is much
larger.
Mapserver image:
http://www.vz.geodan.nl/users/bart/counties_mapserver.png
Arcview screen dump:
http://www.vz.geodan.nl/users/bart/counties_arcview.png
Arcview screen dump of the "broken" part:
http://www.vz.geodan.nl/users/bart/counties_arcview_zoomin.png
Should I file a bug for this and add the shapefile, or is this already a
known issue?
Best regards,
Bart
LAYER
DATA "Nlge_r98"
METADATA
WMS_TITLE "Gemeentes"
WMS_ABSTRACT "Gemeentes via UMN Mapserver"
WMS_SRS "EPSG:28992"
WFS_TITLE "Gemeentes"
RESULT_FIELDS "GEMNAAM"
END
NAME "Gemeentes"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE POLYGON
DUMP TRUE
TEMPLATE "blank.html"
UNITS METERS
CLASS
NAME "Foreign Lands"
STYLE
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 255 0 0
SIZE 1
SYMBOL 0
END
END
END
