[Mapserver-users] Empty screen with .TAB file
Hugo Nathaniel Rodrigues
hugo at pbh.gov.br
Thu Dec 18 10:40:49 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0012_01C3C56C.8C02F610
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
denis, i didnt forgive you, here (in zip files) are the files you sended to
me, with your mapinfo files and the mapserver .map file, i change only 2
things and worked well:
in the EXTENT section, i changed
-5696501 1923039 5696501 11022882
by
-1.178182 -0.352727 0.472727 0.570909
(ogrinfo values with -al option, ogrinfo -al test.tab), and into the layer,
and i change too:
CLASS
END
by
CLASS
OUTLINECOLOR 120 120 120
END
to make the outline color different of white (blank screen?).
now is working well!!!!
cheers
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, December 17, 2003 8:05 AM
Subject: Fw: [Mapserver-users] Empty screen with .TAB file
> From: "Ballini Yvain" <Ballini.Yvain at seat.it>
> To: "Denis Louvegnies" <denis at louvegnies.com>
> Sent: Wednesday, December 17, 2003 10:24 AM
> Subject: R: [Mapserver-users] Empty screen with .TAB file
> I've sent you my map file (demo.map).
> But I've seen in your .sym file that you haven'got the definition of
> mapinfo-sym-111 which is used in my tab file
> (id:"mapinfo-sym-111.ogr-sym-1"), this is probably the cause of my
> problem...
> If you have ogrinfo on your computer, you should try tye command "ogrinfo
> filename.tab filename" to see how is made your tab file (see under for the
> mine).
> If you've got another idea don't hesitate to tell me because I'm blocked
> with that problem now... :(
> Regards :)
> Yvain.
> -----Messaggio originale-----
> Da: Denis Louvegnies [mailto:denis at louvegnies.com]
> Inviato: mercoledì 17 dicembre 2003 10.16
> A: Ballini Yvain
> Oggetto: Re: [Mapserver-users] Empty screen with .TAB file
> Hello Yvain,
> Here is the file. Let me know if this help.
> What do you think I should do? Could you please send me your map file?
> Thanks,
> Denis
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, December 17, 2003 10:10 AM
> Hi Denis,
> I've seen your problem, I get a white map too with my tab file, but I
don't
> think if it's due to the same thing.
> I've seen you're reading the symbolset in the file symbols_mapinfo.sym and
> when I try to read my file arrow.tab with ogrinfo it turns me these
> properties:
> Layer name: arrow
> Geometry: Point
> Feature Count: 267349
> Extent: (6.682870, 36.681040) - (18.495850, 46.895265)
> Layer SRS WKT:
> GEOGCS["unnamed",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563],
> TOWGS84[0,0,0,0,0,0,0]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]]
> LABEL: String (70.0)
> OGRFeature(arrow):1
> LABEL (String) =
> Style = SYMBOL(a:322,c:#4144ae,s:13pt,id:"mapinfo-sym-111.ogr-sym-1")
> POINT (8.85458500 45.96559000)
> OGRFeature(arrow):2
> LABEL (String) =
> Like I said yesterday, I succeed in reading the info about the position
> (that mean the POINT coordinates), but I can't read the symbol (these are
> arrows oriented symbol): if I put TYPE POINT in my mapfile, it turns me a
> non oriented symbol POINT...
> Could you send me your file symbols_mapinfo.sym or give me some additional
> info about it?
> Thanks.
> Yvain.
> Da: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] Per conto di Denis
> Louvegnies
> Inviato: mercoledì 17 dicembre 2003 9.49
> A: Daniel Morissette
> Cc: Hugo Nathaniel Rodrigues; mapserver-users at lists.gis.umn.edu
> Hi Daniel,
> I have tested using php_mapscript_35.dll.
> It seems to be better because I don't get an error but now I get a Empty
> screen....The generated image in empty...
> Here is the map file:
> NAME FIRSTMAP
> SIZE 400 400
> STATUS ON
> #SYMBOLSET ../symbols/symbols.sym
> SYMBOLSET "C:\tmp\ms_tmp\font\symbols_mapinfo.sym"
> EXTENT -5696501 1923039 5696501 11022882 UNITS METERS
> WEB
> IMAGEPATH "/tmp/ms_tmp/"
> IMAGEURL "c:/tmp/ms_tmp/"
> LOG "/tmp/gmap.log"
> END
> LAYER
> NAME test
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION ./test.TAB
> CLASS
> END
> END
> END
> Any idea?
> Many thanks,
> Denis
> From: "Daniel Morissette" <morissette at dmsolutions.ca>
> Cc: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>;
> Sent: Tuesday, December 16, 2003 11:53 PM
> Subject: Re: [Mapserver-users] Empty screen with .tab file?
> > Denis Louvegnies wrote:
> > > Hi Daniel,
> > > Hugo and I have the same problem.
> > > For me even with the absolute path it still doesn't work.
> > > I wounder if any one could open a MapInfo file with
> php_mapscript41.dll....
> > Unfortunately I'm not setup to test on Windows so I can't help. Perhaps
> > you can file a bug with all the details and your data file and if/when
> > another developer on Windows has time to test this then they'll get back
> > to you.
> > BTW, did you try loading the same file with another DLL for version 4.0
> > or 3.6?
> > Daniel Morissette morissette at dmsolutions.ca
> > DM Solutions Group http://www.dmsolutions.ca/
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: application/octet-stream;
name="teste denis.zip"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="teste denis.zip"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==
------=_NextPart_000_0012_01C3C56C.8C02F610--
