Fw: [Mapserver-users] Empty screen with .TAB file
Denis Louvegnies
denis at louvegnies.com
Wed Dec 17 05:05:43 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_005E_01C3C48D.B72BA6F0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
----- Original Message -----
To: "Denis Louvegnies" <denis at louvegnies.com>
Sent: Wednesday, December 17, 2003 10:24 AM
Subject: R: [Mapserver-users] Empty screen with .TAB file
I've sent you my map file (demo.map).
But I've seen in your .sym file that you haven'got the definition of
mapinfo-sym-111 which is used in my tab file
(id:"mapinfo-sym-111.ogr-sym-1"), this is probably the cause of my
problem...
If you have ogrinfo on your computer, you should try tye command "ogrinfo
filename.tab filename" to see how is made your tab file (see under for the
mine).
If you've got another idea don't hesitate to tell me because I'm blocked
with that problem now... :(
Regards :)
Yvain.
-----Messaggio originale-----
Da: Denis Louvegnies [mailto:denis at louvegnies.com]
Inviato: mercoledì 17 dicembre 2003 10.16
A: Ballini Yvain
Oggetto: Re: [Mapserver-users] Empty screen with .TAB file
Hello Yvain,
Here is the file. Let me know if this help.
What do you think I should do? Could you please send me your map file?
Thanks,
Denis
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, December 17, 2003 10:10 AM
Hi Denis,
I've seen your problem, I get a white map too with my tab file, but I don't
think if it's due to the same thing.
I've seen you're reading the symbolset in the file symbols_mapinfo.sym and
when I try to read my file arrow.tab with ogrinfo it turns me these
properties:
Layer name: arrow
Geometry: Point
Feature Count: 267349
Extent: (6.682870, 36.681040) - (18.495850, 46.895265)
Layer SRS WKT:
GEOGCS["unnamed",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
LABEL: String (70.0)
OGRFeature(arrow):1
LABEL (String) =
Style = SYMBOL(a:322,c:#4144ae,s:13pt,id:"mapinfo-sym-111.ogr-sym-1")
POINT (8.85458500 45.96559000)
OGRFeature(arrow):2
LABEL (String) =
Like I said yesterday, I succeed in reading the info about the position
(that mean the POINT coordinates), but I can't read the symbol (these are
arrows oriented symbol): if I put TYPE POINT in my mapfile, it turns me a
non oriented symbol POINT...
Could you send me your file symbols_mapinfo.sym or give me some additional
info about it?
Thanks.
Yvain.
Da: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu] Per conto di Denis
Louvegnies
Inviato: mercoledì 17 dicembre 2003 9.49
A: Daniel Morissette
Cc: Hugo Nathaniel Rodrigues; mapserver-users at lists.gis.umn.edu
Hi Daniel,
I have tested using php_mapscript_35.dll.
It seems to be better because I don't get an error but now I get a Empty
screen....The generated image in empty...
Here is the map file:
NAME FIRSTMAP
SIZE 400 400
STATUS ON
#SYMBOLSET ../symbols/symbols.sym
SYMBOLSET "C:\tmp\ms_tmp\font\symbols_mapinfo.sym"
EXTENT -5696501 1923039 5696501 11022882 UNITS METERS
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "c:/tmp/ms_tmp/"
LOG "/tmp/gmap.log"
END
LAYER
NAME test
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION ./test.TAB
CLASS
END
END
END
Any idea?
Many thanks,
Denis
From: "Daniel Morissette" <morissette at dmsolutions.ca>
Cc: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>;
Sent: Tuesday, December 16, 2003 11:53 PM
Subject: Re: [Mapserver-users] Empty screen with .tab file?
> Denis Louvegnies wrote:
> > Hi Daniel,
> > Hugo and I have the same problem.
> > For me even with the absolute path it still doesn't work.
> > I wounder if any one could open a MapInfo file with
php_mapscript41.dll....
> Unfortunately I'm not setup to test on Windows so I can't help. Perhaps
> you can file a bug with all the details and your data file and if/when
> another developer on Windows has time to test this then they'll get back
> to you.
> BTW, did you try loading the same file with another DLL for version 4.0
> or 3.6?
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: application/octet-stream;
name="demo.map"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="demo.map"
# Start of map file
NAME DEV
STATUS ON
SIZE 430 380
#SIZE 150 150
EXTENT 510350 5035250 510950 5035950
#EXTENT 510350 5035550 510750 5035950
#EXTENT 515050 5035050 515450 5035450 #via Borgospesso
#EXTENT 7.68 45.05 7.7 45.07
UNITS METERS
#SIZE 1000 1000
SYMBOL
NAME "dashed_line"
TYPE ellipse
POINTS 2 2 END
FILLED TRUE
STYLE 2 5 END
END
SYMBOL
NAME "arrow"
TYPE truetype
FONT arial
CHARACTER "O"#" -> =
POSITION CC
GAP -10
END
DEBUG TRUE
SHAPEPATH "data"
IMAGECOLOR 189 198 206
PROJECTION
=20
"proj=3Dutm"
"ellps=3DWGS84"
"datum=3DWGS84"
"zone=3D32"
"north"
"no_defs"
=20
=20
END
#OUTPUTFORMAT
# NAME gif
# DRIVER "GD/GIF"
# MIMETYPE "image/gif"
# IMAGEMODE PC256
# EXTENSION "gif"
#END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
#OUTPUTFORMAT
# NAME jpeg
# DRIVER "GD/JPEG"
# MIMETYPE "image/jpeg"
# IMAGEMODE RGB
# EXTENSION "jpg"
#END
#OUTPUTFORMAT
# NAME wbmp
# DRIVER "GD/WBMP"
# MIMETYPE "image/wbmp"
# IMAGEMODE PC256
# EXTENSION "wbmp"
#END
#OUTPUTFORMAT
# NAME swf
# DRIVER "SWF"
# MIMETYPE "application/x-shockwave-flash"
# EXTENSION "swf"
# IMAGEMODE PC256
# FORMATOPTION "OUTPUT_MOVIE=3DSINGLE"
#END
#IMAGETYPE SWF
IMAGETYPE PNG
#IMAGETYPE PDF
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
#MINSCALE 1000
#MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
END
#FONTSET "c:\windows\fonts\fonts.txt"
FONTSET "C:\WINDOWS\Fonts\Wingdng3.ttf"
#REFERENCE
# IMAGE graphics/reference.gif
# EXTENT 393234.393701263 5205405.16440722 495769.579718949 =
5307959.02579127
# SIZE 120 120
# STATUS ON
# COLOR -1 -1 -1
# OUTLINECOLOR 255 0 0
#END
SYMBOL
NAME 'carto_line'
TYPE CARTOLINE
#Linecap - ROUND, SQUARE, TRIANGLE, BUTT - default BUTT
LINECAP BUTT
#Linejoin - ROUND, BEVEL, MITER - default NONE
#LINEJOIN BEVEL
#LINEJOINMAXSIZE 5
END
SYMBOL
NAME 'cline'
TYPE ellipse
POINTS=20
1 1
END
END
#LAYER
# NAME "grid"
# TYPE line
# STATUS default
# PROJECTION
# "proj=3Dlatlong"
# "ellps=3DWGS84"
# END
# GRID
# MINARCS 2
# MAXARCS 12
# LABELFORMAT "%5.5f"
# END
# CLASS
# SYMBOL "dashed_line"
# COLOR 170 170 200
# LABEL
# TYPE BITMAP
# SIZE SMALL
# COLOR 100 100 230
# SHADOWCOLOR 100 100 130
# END
# END
#END
LAYER
NAME parchi_navtech
STATUS OFF
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
DATA parkcity_region
TYPE POLYGON
LABELITEM "NAME"
CLASS
LABEL
#ANGLE AUTO
#BUFFER 1
#PARTIALS FALSE
#FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION AUTO
SIZE 5
TYPE TRUETYPE
COLOR 255 255 255
END
STYLE
#COLOR 66 132 0
COLOR 77 199 63
ANTIALIAS TRUE
END
END
END # parchi navtech
LAYER
NAME aree_navtech
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
DATA landuseA_region
TYPE POLYGON
LABELITEM "NAME"
CLASS
LABEL
#ANGLE AUTO
#BUFFER 1
#PARTIALS FALSE
#FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION AUTO
SIZE 5
TYPE TRUETYPE
COLOR 255 255 255
END
STYLE
#COLOR 255 165 115
COLOR 179 181 81
ANTIALIAS TRUE
END
END
END # corsi d'acqua navtech
LAYER
NAME acqua_navtech
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
DATA waterwys_region
TYPE POLYGON
#LABELITEM "StNm_Base"
CLASS
STYLE
#COLOR 165 214 255
#COLOR 165 165 165
ANTIALIAS TRUE
COLOR 64 154 253
END
END
LAYER
NAME acqua1_navtech
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
DATA waterwys_polyline
TYPE LINE
CLASS
STYLE
SIZE 1
#COLOR 165 214 255
COLOR 64 154 253
ANTIALIAS TRUE
END
END
LAYER
NAME pedonali_navtech
PROJECTION
=20
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
=20
END
=20
STATUS OFF
DATA pedonali3_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\pedonali1.tab"
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 3
#COLOR 181 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # pedonali navtech
LAYER
NAME vie_navtech
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
DATA vie3_polyline
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 9
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # vie navtech
LAYER
NAME controviali_navtech
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
DATA controviali2_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\controviali1.tab"
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 6
#COLOR 181 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # controviali navtech
LAYER
NAME controviali_navtech2
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
#CONNECTIONTYPE OGR
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 4
COLOR 255 255 255
ANTIALIAS TRUE
END
END
LAYER
NAME corsi_navtech
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
#MAXSCALE 600000
STATUS ON
DATA corsi5_polyline
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 11
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # corsi navtech
LAYER
NAME importanti_navtech
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
DATA importanti5_polyline
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 11
#COLOR 156 202 156
COLOR 88 174 51
ANTIALIAS TRUE
END
END
END # importanti navtech
#LAYER
# NAME statali_navtech
# STATUS OFF
# CONNECTIONTYPE OGR
# CONNECTION "c:\mapserver\itasca\data\statali1.tab"
# TYPE LINE
# CLASS
# STYLE=20
# SYMBOL 'carto_line'
# SIZE 8
#COLOR 156 202 156
# COLOR 88 174 51
# ANTIALIAS TRUE
# END
# END
#END # statali navtech
LAYER
NAME pedonali_navtech2
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
TYPE LINE
LABELCACHE ON
CLASS
LABEL
ANGLE AUTO
FONT "verdana"
#BUFFER 1
#PARTIALS FALSE
ANTIALIAS TRUE
POSITION AUTO
SIZE 5
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE=20
SYMBOL 'carto_line'
#SIZE 2
SIZE 3
#COLOR 217 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
LAYER
NAME vie_navtech2
#MAXSCALE 600000
STATUS OFF
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
DATA vie3_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\vie1.tab"
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 0
PARTIALS TRUE
#FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION CC
SIZE 7
TYPE TRUETYPE
OUTLINECOLOR 255 255 255
COLOR 0 0 0
END
STYLE
SYMBOL 'carto_line'
SIZE 7
COLOR 255 255 255
ANTIALIAS TRUE
END
END
END # vie navtech
LAYER
NAME corsi_navtech2
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS ON
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 2
PARTIALS TRUE
FONT "verdana"
#FORCE TRUE
ANTIALIAS TRUE
MINDISTANCE 4
POSITION CC
SIZE 8
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE=20
SYMBOL 'carto_line'
SIZE 7
COLOR 255 255 255
ANTIALIAS TRUE
END
END
END # corsi navtech
LAYER
NAME importanti_navtech2
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS OFF
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 2
PARTIALS TRUE
FONT "verdana"
ANTIALIAS TRUE
MINDISTANCE 2
FORCE TRUE
POSITION CC
SIZE 8
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE
SYMBOL 'carto_line'
SIZE 7
#COLOR 255 255 132
COLOR 255 255 159
#color 255 255 255
ANTIALIAS TRUE
END
END
#LAYER
# NAME statali_navtech2
# STATUS OFF
# LABELITEM "StNm_Base"
# LABELCACHE ON
# TYPE LINE
# CLASS
# LABEL
# ANGLE AUTO
# BUFFER 1
# PARTIALS TRUE
# FONT "verdana"
# ANTIALIAS TRUE
# MINDISTANCE 2
# FORCE TRUE
# POSITION CC
# SIZE 7
# TYPE TRUETYPE
# COLOR 0 0 0
# END
# STYLE
# SIZE 4
# COLOR 255 255 159
# ANTIALIAS TRUE
# END
# END
#END
#LAYER
# NAME freccie_navtech
# PROJECTION
# "proj=3Dlonglat"
# "ellps=3Dintl"
# "no_defs"
# END
# STATUS OFF
# DATA arrow_font_point
# TYPE LINE#POINT
# CLASS
# STYLE
# SYMBOL 'arrow'
# size 20
# COLOR 245 88 128
# ANTIALIAS TRUE
# END
# END
#END
LAYER
PROJECTION
"proj=3Dlonglat"
"ellps=3Dintl"
"no_defs"
END
STATUS ON
DATA arrow#vie3_polyline
CONNECTIONTYPE OGR
CONNECTION "c:\mapserver\itasca\data\arrow.tab"
STYLEITEM "AUTO"
#FONTSET "C:\WINDOWS\Fonts\Wingdng3.tff"
TYPE polygon
CLASS
#STYLE
#SYMBOL pixmap
#size 20
#COLOR 88 88 245
#ANTIALIAS TRUE
#END
END
END
#LAYER =20
#NAME freccie_navtech#"arrowthings" =20
#PROJECTION
#"proj=3Dlonglat"
#"ellps=3Dintl"
#"no_defs"
#END =20
#TYPE POINT =20
#STATUS OFF
#DATA arrow_font_point#LabelsPippoPluto_text#arrow_font_point=20
=20
#LABELITEM "Label" #field from attribute table to use for =
labelling
#CLASS =20
#SYMBOL 1
#COLOR 245 88 128
#SIZE 50
#LABEL #signifies start of labelling
# BUFFER 1 #space to leave around label
# SIZE small #size of label
# COLOR 255 255 255 #colour of label
# BACKGROUNDCOLOR 128 128 0 #draws a polygon around the label
# POSITION cr #automatically determines position of label
# PARTIALS false #text cannot run off the edge of the map
#END
=20
#CLASS
#NAME "arrow"
#EXPRESSION ([text_angle] > 0 AND [text_angle] < 90)
#SYMBOL "arrow"
#COLOR 245 88 128
#SIZE 20
#BUFFER 1 #space to leave around label
#SIZE small #size of label
#BACKGROUNDCOLOR 128 128 0 #draws a polygon around the label
#POSITION CC #automatically determines position of label
#ANGLE AUTO
#PARTIALS TRUE#false #text cannot run off the edge of the map
#FORCE TRUE
# TYPE TRUETYPE
#END
#END =20
#END #END layer
END # Map File
------=_NextPart_000_005E_01C3C48D.B72BA6F0--
