[Mapserver-users] How to make labels in MS with PostGIS
christian.schuster at rsag.ch
Tue Feb 4 00:03:05 EST 2003
Hi Paul,
Sorry that I am coming back to you after few days. I am still not able to
make labels. I am a newbie and I think it is a generall understanding
problem of how the map file works. Below you see my layer definitions for
the labels. There I have a big question about it. So I have a table called
'geo3'. In this table I have a column as identifier which is called 'ID'.
Then the second column is of type varcahr(20 and called 'NAME'. The last
one is the geometry column. Now I can draw the map and all. Just the labels
are not working. I am not sure what the tag 'DATA' has to look like. The
way it is now, I just get back the geometry column. But what I would like
is to have the column 'NAME' to use for labeling. If I change the tag
'DATA' to "NAME from geo3" then I would have this. But I do not know how
MapServer knows where to draw the labels. If I change the tag 'DATA' to "*
from geo" then I get an error. So I am quite confused. I also tried so many
times already. if someone could solve my confusion would be really nice.
LAYER
NAME "labels"
### Connect to a remote spatial database
CONNECTIONTYPE postgis
CONNECTION "user=*** dbname=myGISdb host=127.0.0.1 port=5432"
### Get the labels from the table
DATA "geom from geo3"
STATUS ON
TYPE ANNOTATION
LABELITEM "name"
CLASS
EXPRESSION 'name'
COLOR -1 -1 -1
LABEL
COLOR 0 0 0
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS FALSE
BUFFER 2
END # end of label
END
END
Christian Schuster
Rudolf Schuster AG
Postfach 277
CH - 3000 Bern 11
http://www.rsag.ch
++41 31 348 05 30
Paul Ramsey
<pramsey at refracti
ons.net> To
31.01.2003 17:18 cc
mapserver-users at lists.gis.umn.edu
Subject
Re: [Mapserver-users] How to make
Same as with any other data source. Declare a labelitem and add a label
object to your class object. Should be examples in the map file
reference page. The only potential gotcha is that your labelitem
attribute should be given in lower case.
christian.schuster at rsag.ch wrote:
> Hi list,
> I have a table 'geo' with a geometry column, a column 'name' as
> varchar(20) and an ID column as the Primary Key. Is it possible to use
> the text in the column 'name' as the label text and if so what does the
> layer look like in the map file.
> Thanaks for helping
> Christian Schuster
> Rudolf Schuster AG
> Postfach 277
> CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
