[Mapserver-users] can't get tutorial working on windows
Pericles Nacionales
nacional at cbs.umn.edu
Sat Feb 1 00:59:36 EST 2003
Chris,
Your "IMAGEURL" is always relative to the web server's root. So,
don't add "http://localhost" but rather specify the line like this:
IMAGEURL "/mapserverapps/data/tmp/"
I hope this helps.
-Perry
On Fri, 31 Jan 2003, Chris Black wrote:
> Folks,
> I've downloaded the tutorial, and I'm trying to get section 3, example 2
> working on windows and I just can't get it going. When I go to the url (
> http://localhost/Scripts/mapserv.exe?map=c%3A%2Finetpub%2Fwwwroot%2Fmapserverapps%2Ftutorial35%2Fs3%2Fs3ex2.map&imgext=-97.500000+39.736083+-82.122902+51.269315&zoom=1
> I get a page with the layout of the page I find at
> http://terrasip.gis.umn.edu/cgi-bin/mapserv35?map=/data/projects/tutorial35/s3/s3ex2.map
> . But where the map should be, it just says "Submit Query", and the
> legend and reference image are blank. I modified the tutorial files to
> have what I think are the correct paths and urls, but clearly I've done
> something wrong. I'll include here my versions of s3ex2.map and
> s3ex2.html as well as a directory listing of . I hope someone can find
> where I've botched the paths, because it all looks ok to me.
> Thank you for any help.
> -- Chris
> s3ex2.html
> --------------- cut here -----------------------
> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
> <html>
> <head>
> <title>MapServer 3.5 Tutorial</title>
> <link type="text/css" rel="stylesheet"
> href="/mapserverapps/tutorial35/ms35.css" />
> </head>
> <body>
> <h3>Section 3<br>
> Example 2 – Zoom Controls</h3>
> <p>
> <form method="GET" action="/Scripts/mapserv.exe">
> <input type="hidden" name="map" value="[map]">
> <input type="hidden" name="imgext" value="[mapext]">
> [<a href="/mapserverapps/tutorial35/s3/s3ex2_map.html">map file
> listing</a>]
> [<a href="/mapserverapps/tutorial35/s3/s3ex2.html">template file
> listing</a>]
> <table border=1 cellpadding=3>
> <tr>
> <td align=center>
> <input type="image" name="img" src="[img]" border="0">
> </td>
> <td valign=top>
> <font size=+1 face=arial,helvetica>Map Controls</font>
> <p>
> Set your zoom option:<br>
> <select name="zoom" size="1">
> <option value="10" [zoom_10_select]> Zoom in 10 times
> <option value="8" [zoom_8_select]> Zoom in 8 times
> <option value="4" [zoom_4_select]> Zoom in 4 times
> <option value="3" [zoom_3_select]> Zoom in 3 times
> <option value="2" [zoom_2_select]> Zoom in 2 times
> <option value="1" [zoom_1_select]> Recenter Map
> <option value="-2" [zoom_-2_select]> Zoom out 2 times
> <option value="-3" [zoom_-3_select]> Zoom out 3 times
> <option value="-4" [zoom_-4_select]> Zoom out 4 times
> <option value="-8" [zoom_-8_select]> Zoom out 8 times
> <option value="-10" [zoom_-10_select]> Zoom out 10 times
> </select>
> <p>
> <font face=arial,helvetica><b>Legend</b></font><br>
> <img src="[legend]"><p>
> <img src="[ref]">
> </td>
> </tr></table>
> <p> <a href="index.html">Back to Section 3</a> | <a
> href="/Scripts/mapserv.exe?map=c:\inetpub\wwwroot\mapserverapps\tutorial35\s3\s3ex3.map&layer=water&layer=states&zoom=1&submit=Redraw">Proceed
> to Example 3</a>
> </form>
> </body>
> </html>
> -------------- cut here -------------------------
> s3ex2.map
> ---------------- cut here --------------------------
> NAME S3EX1
> EXTENT -97.5 41.619778 -82.122902 49.38562
> SIZE 400 300
> SHAPEPATH "c:/inetpub/wwwroot/mapserverapps/tutorial35/data"
> FONTSET "c:/inetpub/wwwroot/mapserverapps/fonts/fonts.list"
> SYMBOLSET
> "c:/inetpub/wwwroot/mapserverapps/tutorial35/symbols/symbols35.sym"
> WEB
> TEMPLATE s3ex2.html
> IMAGEPATH "c:/inetpub/wwwroot/mapserverapps/data/tmp/"
> IMAGEURL "http://localhost/mapserverapps/data/tmp/"
> END
> LEGEND
> STATUS ON
> LABEL
> TYPE TRUETYPE
> FONT arial
> COLOR 0 0 0
> SIZE 12
> ANTIALIAS TRUE
> END
> END
> REFERENCE
> STATUS ON
> IMAGE "../images/ref1.gif"
> SIZE 150 113
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> # LAYER DEFINITIONS ---------------------------------------------
> LAYER # Shaded Relief Raster
> NAME "relief"
> DATA "raster/shdrlfi020g_ugl.tif"
> STATUS DEFAULT
> TYPE RASTER
> OFFSITE 0
> END
> LAYER # States
> NAME "states"
> DATA states_ugl
> STATUS OFF
> TYPE POLYGON
> # CLASSITEM "CLASS"
> CLASS # States class
> NAME "States"
> EXPRESSION ('[CLASS]' eq 'land')
> # EXPRESSION 'land'
> COLOR 240 240 240
> OUTLINECOLOR 0 0 0
> END # end of States class object
> END # end of layer object
> LAYER # water features layer
> NAME "water features"
> DATA hydrop_ugl
> STATUS DEFAULT
> TYPE POLYGON
> CLASSITEM "FEATURE"
> CLASS
> NAME "Bay/Estuarine"
> EXPRESSION /Bay*/
> COLOR 164 164 255
> END
> CLASS
> NAME "Lakes/Reservoir"
> EXPRESSION ('[FEATURE]' eq 'Lake' or '[FEATURE]' = 'Reservoir')
> COLOR 64 64 255
> END
> CLASS
> NAME "Marsh/Swamp"
> EXPRESSION /Sw*/
> COLOR 210 235 255
> END
> CLASS
> NAME "Major Rivers"
> EXPRESSION 'Stream'
> COLOR 128 128 220
> END
> CLASS
> NAME "Canal"
> EXPRESSION 'Canal'
> COLOR 200 128 255
> END
> END # end of water features layer
> #LAYER # Roads
> # NAME "roads"
> # DATA roads_ugl
> # TYPE LINE
> # STATUS DEFAULT
> # CLASSITEM "CLASS"
> # CLASS
> # NAME "Interstate Highways"
> # EXPRESSION 'Interstate'
> # COLOR 128 0 0
> # SYMBOL 'circle'
> # SIZE 2
> # END
> # CLASS
> # NAME "US Highways"
> # EXPRESSION 'US'
> # COLOR 255 128 0
> # SYMBOL 'line1'
> # SIZE 1
> # END
> #END
> LAYER # States
> NAME "states"
> DATA states_ugl
> STATUS DEFAULT
> TYPE LINE
> # CLASSITEM "CLASS"
> NAME "States"
> # EXPRESSION 'land'
> COLOR 0 0 0
> LAYER # States
> NAME "states"
> DATA states_ugl
> STATUS DEFAULT
> TYPE ANNOTATION
> LABELITEM "STATE"
> CLASSITEM "CLASS"
> EXPRESSION 'land'
> COLOR -1 -1 -1
> LABEL
> COLOR 132 31 31
> SHADOWCOLOR 218 218 218
> SHADOWSIZE 2 2
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 14
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 250
> BUFFER 4
> END # end of label
> END # end of map file
> ---------------- cut here ---------------------------
> Directory listing -- this looks like a Unix directory listing because
> it's the output of the cygwin command "ls - R" in the directory
> c:\inetpub\wwwroot
> This is a Windows system, though.
> total 47
> drwxr-xr-x 6 Administ None 4096 Jan 31 15:25 MapServerApps
> drwxrwxrwx 2 Administ None 0 Jan 7 13:32 _private
> drwxr-xr-x 2 Administ None 4096 Jan 10 10:16 _vti_cnf
> -rwxr-xr-x 1 Administ None 1759 Jan 7 13:32 _vti_inf.html
> drwxrwxrwt 2 Administ None 0 Jan 7 13:32 _vti_log
> drwxrwxrwt 2 Administ None 4096 Jan 10 10:20 _vti_pvt
> drwxr-xr-x 2 Administ None 0 Jan 7 13:32 _vti_script
> drwxrwxrwt 2 Administ None 0 Jan 7 13:32 _vti_txt
> -rwxr-xr-x 1 Administ None 451 Jan 7 13:49 default.htm
> -rw-rw-rw- 1 Administ None 0 Jan 31 15:28 flist.out
> -rwxr-xr-x 1 Administ None 79 Feb 17 1998 global.asa
> -rwxr-xr-x 1 Administ None 1736 Jun 4 1999 iisstart.asp
> drwxr-xr-x 2 Administ None 0 Jan 7 13:32 images
> -rwxr-xr-x 1 Administ None 7240 Sep 22 1999 localstart.asp
> -rwxr-xr-x 1 Administ None 1684 Jan 24 11:08
> mapserver_documentation.htm
> -rwxr-xr-x 1 Administ None 2497 Jan 7 13:32 postinfo.html
> drwxrwxrwx 2 Administ None 0 Jan 31 15:27 tmp
> ./MapServerApps:
> total 8
> drwxr-xr-x 5 Administ None 0 Jan 31 14:55 data
> drwxr-xr-x 2 Administ None 4096 Jan 31 14:34 fonts
> drwxr-xr-x 2 Administ None 0 Jan 27 16:22 images
> drwxr-xr-x 12 Administ None 4096 Jan 31 14:21 tutorial35
> ./MapServerApps/data:
> total 0
> drwxr-xr-x 2 Administ None 0 Jan 27 16:22 raster
> drwxr-xr-x 2 Administ None 0 Jan 31 14:55 tmp
> drwxr-xr-x 2 Administ None 0 Jan 27 16:22 vector
> ./MapServerApps/data/raster:
> total 0
> ./MapServerApps/data/tmp:
> total 0
> ./MapServerApps/data/vector:
> total 0
> ./MapServerApps/fonts:
> total 547
> -rwxr-xr-x 1 Administ None 273020 Jul 26 2000 ARIAL.TTF
> -rwxr-xr-x 1 Administ None 284560 Jul 26 2000 ARIALBD.TTF
> -rwxr-xr-x 1 Administ None 41 Jan 31 14:21 fonts.list
> -rwxr-xr-x 1 Administ None 71 Jan 31 14:15 fonts.list~
> ./MapServerApps/images:
> total 0
> ./MapServerApps/tutorial35:
> total 69
> -rwxr-xr-x 1 Administ None 1130 Jul 6 2002 LICENSE.txt
> drwxr-xr-x 3 Administ None 16384 Jan 31 13:32 data
> -rwxr-xr-x 1 Administ None 1069 Apr 26 2002 download.html
> -rwxr-xr-x 1 Administ None 75 Jan 31 14:14 fonts.list~
> drwxr-xr-x 2 Administ None 0 Jan 31 13:32 images
> -rwxr-xr-x 1 Administ None 8713 Jul 6 2002 index.html
> drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 java
> -rwxr-xr-x 1 Administ None 2574 Mar 8 2002 markup.css
> -rwxr-xr-x 1 Administ None 860 Apr 14 2002 ms35.css
> drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s1
> drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s2
> drwxr-xr-x 2 Administ None 8192 Jan 31 15:01 s3
> drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s4
> drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s5
> drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s6
> -rwxr-xr-x 1 Administ None 1628 Jul 6 2002 sections.html
> drwxr-xr-x 2 Administ None 0 Jan 31 13:32 symbols
> -rwxr-xr-x 1 Administ None 118 Apr 11 2002 tutorial35_tree.txt
> ./MapServerApps/tutorial35/data:
> total 16978
> -rwxr-xr-x 1 Administ None 43103 Mar 7 2002 co2000_ugl.dbf
> -rwxr-xr-x 1 Administ None 10180 Mar 7 2002 co2000_ugl.sbn
> -rwxr-xr-x 1 Administ None 900 Mar 7 2002 co2000_ugl.sbx
> -rwxr-xr-x 1 Administ None 667172 Mar 7 2002 co2000_ugl.shp
> -rwxr-xr-x 1 Administ None 3708 Mar 7 2002 co2000_ugl.shx
> -rwxr-xr-x 1 Administ None 25673 Feb 6 2002 co2000p020.txt
> -rwxr-xr-x 1 Administ None 210750 Mar 7 2002 fedlan_ugl.dbf
> -rwxr-xr-x 1 Administ None 227456 Mar 7 2002 fedlan_ugl.shp
> -rwxr-xr-x 1 Administ None 2500 Mar 7 2002 fedlan_ugl.shx
> -rwxr-xr-x 1 Administ None 41117 Jan 15 2002 fedlanp020.txt
> -rwxr-xr-x 1 Administ None 33429 Sep 27 2001 hydrogm020.txt
> -rwxr-xr-x 1 Administ None 1183928 Mar 7 2002 hydrol_ugl.dbf
> -rwxr-xr-x 1 Administ None 2332764 Mar 7 2002 hydrol_ugl.shp
> -rwxr-xr-x 1 Administ None 39884 Mar 7 2002 hydrol_ugl.shx
> -rwxr-xr-x 1 Administ None 506006 Mar 7 2002 hydrop_ugl.dbf
> -rwxr-xr-x 1 Administ None 2290160 Mar 7 2002 hydrop_ugl.shp
> -rwxr-xr-x 1 Administ None 17244 Mar 7 2002 hydrop_ugl.shx
> -rwxr-xr-x 1 Administ None 3619390 Mar 7 2002 plss00_ugl.dbf
> -rwxr-xr-x 1 Administ None 1370568 Mar 7 2002 plss00_ugl.shp
> -rwxr-xr-x 1 Administ None 52172 Mar 7 2002 plss00_ugl.shx
> -rwxr-xr-x 1 Administ None 30501 Aug 27 2001 plss00p020.txt
> drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 raster
> -rwxr-xr-x 1 Administ None 1049116 Mar 14 2002 roads.dbf
> -rwxr-xr-x 1 Administ None 40964 Mar 14 2002 roads.sbn
> -rwxr-xr-x 1 Administ None 3908 Mar 14 2002 roads.sbx
> -rwxr-xr-x 1 Administ None 766496 Mar 14 2002 roads.shp
> -rwxr-xr-x 1 Administ None 29332 Mar 14 2002 roads.shx
> -rwxr-xr-x 1 Administ None 1049116 Apr 23 2002 roads_ugl.dbf
> -rwxr-xr-x 1 Administ None 766496 Mar 7 2002 roads_ugl.shp
> -rwxr-xr-x 1 Administ None 29332 Mar 7 2002 roads_ugl.shx
> -rwxr-xr-x 1 Administ None 31134 Sep 25 2001 roadtrl020.txt
> -rwxr-xr-x 1 Administ None 13078 Mar 7 2002 states_ugl.dbf
> -rwxr-xr-x 1 Administ None 520236 Mar 7 2002 states_ugl.shp
> -rwxr-xr-x 1 Administ None 1732 Mar 7 2002 states_ugl.shx
> -rwxr-xr-x 1 Administ None 19317 Sep 6 2001 statesp020.txt
> -rwxr-xr-x 1 Administ None 111 Mar 7 2002 uglbound.dbf
> -rwxr-xr-x 1 Administ None 81868 Mar 7 2002 uglbound.shp
> -rwxr-xr-x 1 Administ None 108 Mar 7 2002 uglbound.shx
> -rwxr-xr-x 1 Administ None 58761 Mar 7 2002 urban_ugl.dbf
> -rwxr-xr-x 1 Administ None 168412 Mar 7 2002 urban_ugl.shp
> -rwxr-xr-x 1 Administ None 4172 Mar 7 2002 urban_ugl.shx
> -rwxr-xr-x 1 Administ None 17679 Oct 29 2001 urbanap020.txt
> ./MapServerApps/tutorial35/data/raster:
> total 15829
> -rwxr-xr-x 1 Administ None 6529545 Apr 24 2002
> mod13a12000257evi.tif
> -rwxr-xr-x 1 Administ None 6433369 Apr 23 2002
> mod13a12000257evi_l.tif
> -rwxr-xr-x 1 Administ None 2118176 Apr 24 2002 shdrlfi020g_ugl.tif
> -rwxr-xr-x 1 Administ None 94 Mar 13 2002 shdrlfi020g_ugl.wld
> -rwxr-xr-x 1 Administ None 1123518 Apr 14 2002 shdrlfi020l_ugl.tif
> -rwxr-xr-x 1 Administ None 87 Apr 14 2002 shdrlfi020l_ugl.wld
> ./MapServerApps/tutorial35/images:
> total 6
> ./MapServerApps/tutorial35/java:
> total 29
> -rwxr-xr-x 1 Administ None 2691 Dec 22 2000 README
> -rwxr-xr-x 1 Administ None 1243 Feb 13 2001 evalThread.class
> -rwxr-xr-x 1 Administ None 6600 Feb 13 2001 mapplet.class
> -rwxr-xr-x 1 Administ None 7918 Feb 2 2001 mapplet.java
> -rwxr-xr-x 1 Administ None 8471 Jul 6 2001 mapplet.zip
> ./MapServerApps/tutorial35/s1:
> total 23
> -rwxr-xr-x 1 Administ None 1098 Apr 26 2002 index.html
> -rwxr-xr-x 1 Administ None 1891 Apr 30 2002 s1ex1.html
> -rwxr-xr-x 1 Administ None 709 Apr 30 2002 s1ex1.map
> -rwxr-xr-x 1 Administ None 1814 Mar 14 2002 s1ex1_code.html
> -rwxr-xr-x 1 Administ None 1211 Apr 30 2002 s1ex1_map.html
> -rwxr-xr-x 1 Administ None 1239 Apr 28 2002 s1ex2.html
> -rwxr-xr-x 1 Administ None 1644 Apr 30 2002 s1ex2.map
> -rwxr-xr-x 1 Administ None 1774 Mar 14 2002 s1ex2_code.html
> -rwxr-xr-x 1 Administ None 1445 Mar 14 2002 s1ex2_map.html
> -rwxr-xr-x 1 Administ None 970 Apr 28 2002 s1ex3.html
> -rwxr-xr-x 1 Administ None 738 Apr 30 2002 s1ex3.map
> -rwxr-xr-x 1 Administ None 1906 Mar 14 2002 s1ex3_code.html
> -rwxr-xr-x 1 Administ None 1170 Mar 14 2002 s1ex3_map.html
> ./MapServerApps/tutorial35/s2:
> total 37
> -rwxr-xr-x 1 Administ None 1377 May 2 2002 index.html
> -rwxr-xr-x 1 Administ None 1221 Apr 28 2002 s2ex1.html
> -rwxr-xr-x 1 Administ None 712 Mar 14 2002 s2ex1.map
> -rwxr-xr-x 1 Administ None 933 Mar 14 2002 s2ex1_code.html
> -rwxr-xr-x 1 Administ None 1420 Mar 14 2002 s2ex1_map.html
> -rwxr-xr-x 1 Administ None 974 Apr 28 2002 s2ex2.html
> -rwxr-xr-x 1 Administ None 1117 Mar 14 2002 s2ex2.map
> -rwxr-xr-x 1 Administ None 1119 Mar 14 2002 s2ex2_code.html
> -rwxr-xr-x 1 Administ None 1597 Apr 28 2002 s2ex2_map.html
> -rwxr-xr-x 1 Administ None 2199 Apr 28 2002 s2ex3.html
> -rwxr-xr-x 1 Administ None 1542 Apr 26 2002 s2ex3.map
> -rwxr-xr-x 1 Administ None 2022 Apr 28 2002 s2ex3_map.html
> -rwxr-xr-x 1 Administ None 1057 Apr 28 2002 s2ex4.html
> -rwxr-xr-x 1 Administ None 2009 Apr 26 2002 s2ex4.map
> -rwxr-xr-x 1 Administ None 2489 Apr 28 2002 s2ex4_map.html
> -rwxr-xr-x 1 Administ None 1781 Apr 28 2002 s2ex5.html
> -rwxr-xr-x 1 Administ None 2122 Apr 26 2002 s2ex5.map
> -rwxr-xr-x 1 Administ None 2602 May 2 2002 s2ex5_map.html
> ./MapServerApps/tutorial35/s3:
> total 61
> -rwxr-xr-x 1 Administ None 12 Nov 22 2000 county_footer.html
> -rwxr-xr-x 1 Administ None 135 May 2 2002 county_header.html
> -rwxr-xr-x 1 Administ None 43 May 6 2002 county_query.html
> -rwxr-xr-x 1 Administ None 12 Nov 22 2000 fed_footer.html
> -rwxr-xr-x 1 Administ None 193 May 2 2002 fed_header.html
> -rwxr-xr-x 1 Administ None 114 May 2 2002 fed_query.html
> -rwxr-xr-x 1 Administ None 451 Jul 5 2002 footer.html
> -rwxr-xr-x 1 Administ None 154 May 2 2002 header.html
> -rwxr-xr-x 1 Administ None 1590 Jan 31 13:44 index.html
> -rwxr-xr-x 1 Administ None 1536 Jan 31 13:42 index.html~
> -rwxr-xr-x 1 Administ None 4690 May 2 2002 s3ex1.html
> -rwxr-xr-x 1 Administ None 1958 Jan 31 14:34 s3ex2.html
> -rwxr-xr-x 1 Administ None 1943 Jan 31 14:31 s3ex2.html~
> -rwxr-xr-x 1 Administ None 3120 Jan 31 15:01 s3ex2.map
> -rwxr-xr-x 1 Administ None 3115 Jan 31 15:00 s3ex2.map~
> -rwxr-xr-x 1 Administ None 3482 May 2 2002 s3ex2_map.html
> -rwxr-xr-x 1 Administ None 2803 Jul 5 2002 s3ex3.html
> -rwxr-xr-x 1 Administ None 2918 Apr 26 2002 s3ex3.map
> -rwxr-xr-x 1 Administ None 3398 May 2 2002 s3ex3_map.html
> -rwxr-xr-x 1 Administ None 3185 Jul 5 2002 s3ex4.html
> -rwxr-xr-x 1 Administ None 3571 Jul 5 2002 s3ex4.map
> -rwxr-xr-x 1 Administ None 3398 May 2 2002 s3ex4_map.html
> -rwxr-xr-x 1 Administ None 12 Nov 22 2000 urban_footer.html
> -rwxr-xr-x 1 Administ None 136 May 2 2002 urban_header.html
> -rwxr-xr-x 1 Administ None 41 May 2 2002 urban_query.html
> -rwxr-xr-x 1 Administ None 12 Nov 22 2000 water_footer.html
> -rwxr-xr-x 1 Administ None 162 May 2 2002 water_header.html
> -rwxr-xr-x 1 Administ None 59 May 2 2002 water_query.html
> ./MapServerApps/tutorial35/s4:
> total 27
> -rwxr-xr-x 1 Administ None 2670 Jul 5 2002 index.html
> -rwxr-xr-x 1 Administ None 2508 Jul 5 2002 s4ex1.html
> -rwxr-xr-x 1 Administ None 3754 Jul 5 2002 s4ex1.map
> -rwxr-xr-x 1 Administ None 4533 Jul 5 2002 s4ex1_map.html
> -rwxr-xr-x 1 Administ None 2499 Jul 5 2002 s4ex2.html
> -rwxr-xr-x 1 Administ None 3835 Jul 5 2002 s4ex2.map
> -rwxr-xr-x 1 Administ None 4509 Jul 5 2002 s4ex2_map.html
> ./MapServerApps/tutorial35/s5:
> total 27
> -rwxr-xr-x 1 Administ None 2215 Jul 5 2002 index.html
> -rwxr-xr-x 1 Administ None 2941 Apr 24 2002 s5ex1.html
> -rwxr-xr-x 1 Administ None 4056 Jul 5 2002 s5ex1.map
> -rwxr-xr-x 1 Administ None 4535 Jul 5 2002 s5ex1_map.html
> -rwxr-xr-x 1 Administ None 3052 Jul 5 2002 s5ex3.html
> -rwxr-xr-x 1 Administ None 9009 Jul 6 2002 s5ex3.map
> ./MapServerApps/tutorial35/s6:
> total 32
> -rwxr-xr-x 1 Administ None 451 Jul 6 2002 footer.html
> -rwxr-xr-x 1 Administ None 2261 Jul 6 2002 index.html
> -rwxr-xr-x 1 Administ None 4039 Jul 6 2002 s6ex1.html
> -rwxr-xr-x 1 Administ None 10467 Jul 6 2002 s6ex1.map
> ./MapServerApps/tutorial35/symbols:
> total 2
> -rwxr-xr-x 1 Administ None 1166 Jan 9 2002 symbols35.sym
> ./_private:
> total 0
> ./_vti_cnf:
> total 15
> -rwxr-xr-x 1 Administ None 791 Jan 7 13:49 default.htm
> -rwxr-xr-x 1 Administ None 380 Jan 7 13:32 global.asa
> -rwxr-xr-x 1 Administ None 344 Jan 7 13:32 help.gif
> -rwxr-xr-x 1 Administ None 562 Jan 7 13:32 iisstart.asp
> -rwxr-xr-x 1 Administ None 1075 Jan 7 13:32 localstart.asp
> -rwxr-xr-x 1 Administ None 2080 Jan 10 11:07
> -rwxr-xr-x 1 Administ None 344 Jan 7 13:32 mmc.gif
> -rwxr-xr-x 1 Administ None 341 Jan 7 13:32 pagerror.gif
> -rwxr-xr-x 1 Administ None 345 Jan 7 13:32 print.gif
> -rwxr-xr-x 1 Administ None 345 Jan 7 13:32 warning.gif
> -rwxr-xr-x 1 Administ None 345 Jan 7 13:32 web.gif
> -rwxr-xr-x 1 Administ None 347 Jan 7 13:32 win2000.gif
> ./_vti_log:
> total 0
> ./_vti_pvt:
> total 18
> -rwxrwxrwx 1 Administ None 113 Jan 7 13:32 access.cnf
> -rwxrwxrwx 1 Administ None 146 Jan 7 13:32 botinfs.cnf
> -rwxrwxrwx 1 Administ None 323 Jan 7 13:32 bots.cnf
> -rwxrwxrwx 1 Administ None 324 Jan 10 11:07 deptodoc.btr
> -rwxrwxrwx 1 Administ None 5616 Jan 10 11:07 doctodep.btr
> -rwxrw-rw- 1 Administ None 0 Jan 7 13:32 frontpg.lck
> -rwxrwxrwx 1 Administ None 1125 Jan 10 10:20 linkinfo.cnf
> -rwxrw-rw- 1 Administ None 1437 Jan 7 13:43 service.cnf
> -rwxrw-rw- 1 Administ None 0 Jan 10 11:07 service.lck
> -rwxrwxrwx 1 Administ None 3 Jan 7 13:32 services.cnf
> -rwxrwxrwx 1 Administ None 89 Jan 10 10:20 structure.cnf
> -rwxrwxrwx 1 Administ None 66 Jan 7 13:32 svcacl.cnf
> -rwxrw-rw- 1 Administ None 0 Jan 7 13:32 uniqperm.cnf
> -rwxrwxrwx 1 Administ None 25 Jan 7 13:32 writeto.cnf
> ./_vti_script:
> total 0
> ./_vti_txt:
> total 0
> ./images:
> total 0
> ./tmp:
> total 0
> ----------------------- cut here -----------------------
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
