[Mapserver-users] Compilation Question
    Daniel Morissette
    morissette at dmsolutions.ca
    Tue Feb  4 09:00:27 PST 2003
Kevin Slover wrote:
>         One last question... thought I would try without GDAL support, and had
> the make run through successfully.  However, in make install, it was
> attempting to copy map.h from an old install of Mapserver (a previous,
> extremely unsuccessful attempt).  It is in the Makefile script at:
> cp -f map.h , attempting to install libmap.a.  Should I download a copy
> of Mapserver 3.5, configure, and then make clean to solve this problem??
The 'make install' target in the MapServer makefile should not be used,
it will just cause you trouble.  Now that you've used it once, just
delete /usr/local/lib/libmap.a and /usr/local/include/mapserver/map.h
and keep going with your build.  To install MapServer just copy the
'mapserv' executable to your CGI directory and the installation will be
done.
 Daniel Morissette               morissette at dmsolutions.ca
 DM Solutions Group              http://www.dmsolutions.ca/
More information about the MapServer-users
