[Mapserver-users] mapscript: querying w/o shape files
Dylan Keon
keon at nacse.org
Wed Feb 5 15:59:48 EST 2003
Eric Bridger wrote:
> Using mapscript (mapserv 3.6.4) I am populating and drawing a layer with
> point objects. I'm getting lat,lon and a text label from a mySQL
> database, in other words, from a data source or connection type not
> supported by MS. What are my options for using layer->queryByPoint() on
> this layer, if any?
> Since I know the order I've added the points I can track the record id
> of the points. Do I need to create a dummy *.dbf file, a real *.dbf
> file? Is there some way to use MS_INLINE or perhaps layer->addFeature()
> or access the labels for the points created to allow me to query a layer
> created on the fly?
You may want to actually create a shapefile (and dbf file) on the fly
instead of just grabbing the points and plotting them. I use PHP and
MapScript to grab point coordinates and associated data from a Sybase
database and write them to a shapefile. I can then use that shapefile
like I would any other (including queryByPoint() ). It works well.
Dylan Keon
GIS/Database Research Specialist
Northwest Alliance for Computational
Science and Engineering (NACSE)
Oregon State University
Corvallis, OR 97331
keon at nacse.org (541) 737-6608
