[Mapserver-users] PHP4/MapScript bug
strk
strk at keybit.net
Thu Feb 6 06:57:52 EST 2003
Hello,
I'm having problem with MapScript compiled against PHP-4.3.0
A map created with the save() function is not readable by
ms_newMapObj()
Message from ms_newMapObj() is:
Warning: MapServer Error in getSymbol(): (QUERYONLY):(29)
Fatal error: Failed to open map file test.map-707.map
The file 'test.map-707.map' as been created with
$map->save('test.map-707.map') as the result of manipulation
of original map 'test.map'.
The original map (test.map) is read correctly, no errors given,
no QUERYONLY keyword present.
MapScript come from release 3.6.3 of MapServer.
Any hint ?
TIA,
--strk;
