[Mapserver-users] create and display point obj on the fly
Lowell Filak
lfilak at medinaco.org
Thu Feb 6 09:52:45 EST 2003
You are correct, it is a simple matter of order in the dbf file.
The only exception is that record #1 in the dbf file corresponds to shape #0.
HTH
Lowell F.
The following message was sent by Lionel Bargeot <l.bargeot at educagri.fr> on 04 Feb 2003 15:37:08 +0100.
> Le mer 05/02/2003 à 22:23, Hankley, Chip a écrit :
> > In PHP-MapScript, I create the Dbase file using the xBase functions that
> > are
> > part of PHP.
> > http://www.php.net/manual/en/ref.dbase.php
> > In particular, check out dbase_create:
> > http://www.php.net/manual/en/function.dbase-create.php
> hi,
> thanks for this suggestion, i will have test on it today. But could you
> tell me if it's easy to populate a dbase file to abtain a valid (.shp,
> .shx, .dbf) group of file.
> I don't know anything about keeping link between the geography data
> (.shp, .shx) and semantic data (.dbf). Is it a simple question of order
> in the dbf file. Will the order in the dbf correspond to shapes index ?
> If you have any experience on this subject, let me know
> thanks
> Lionel
> AgrogeomaTIC
> CNERTA-ENESAD, 4 rue champs-prevois, batiment grand-champs, 21000 Dijon
> 03.80.77.28.49
> http://stb.educagri.fr
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
