[Mapserver-users] mapscript: querying w/o shape files
Eric Bridger
eric at gomoos.org
Thu Feb 6 10:20:03 EST 2003
Well, I did finally figure out how to do this so I will answer my own
question. It seems like this might be a common thing to do. I am using
Perl mapscript, but I imagine it would work with PHP mapscript as well.
You can create a layer of point objects which are queryable by creating
them as Features. Using $layer->addFeature(shape) sets the connection
type to MS_INLINE, which makes the layer queryable w/o a shape file or
DB connection. Some code snippets:
# points are in a hash: point_id => {latitude => y, longitude => x}
# Queries will return index into this array. so save the point name here
my @point_lookup = ();
my $i = 0;
my $layerObj = $map->getLayerByName('points');
my $point = new mapscript::pointObj();
# add point features to the layer
foreach my $point_id (keys %points){
$point->{x} = $points{$point_id}{longitude};
$point->{y} = $points{$point_id}{latitude};
my $line = new mapscript::lineObj();
$line->add($point);
my $shp = new mapscript::shapeObj($mapscript::MS_SHAPE_POINT);
$shp->add($line);
$shp->setBounds();
$shp->{text} = $point_id;
$shp->{index} = $i;
if($layerObj->addFeature($shp) == -1){
warn "addFeature failed\n";
next;
push @point_lookup, $point_id;
$i++;
$layerObj->draw($map, $img);
# To query the layer assuming a point object containing the user's mouse
# click. $click_pt
if($layerObj->queryByPoint($map,$click_pt,$mapscript::MS_SINGLE,0)){
print "No points found<br>\n";
}else{
my $rslt = $layerObj->getResult(0);
my $record = $rslt->{shapeindex};
my $point_name = $point_lookup[$record];
print "You clicked: $point_name.<br>\n";
And a minimal map file: Note: you must have a TEMPLATE in the layer in
order for queryByPoint(), etc. to work.
MAP
STATUS ON
EXTENT -71.5 39.5 -63.0 46.0
SIZE 504 385
IMAGETYPE PNG
UNITS DD
SYMBOL
TYPE ELLIPSE
NAME "circle"
POINTS 1 1 END
FILLED TRUE
END
LAYER
NAME "points"
TYPE POINT
STATUS ON
TOLERANCE 10
# Need fake template for querys to work
TEMPLATE "bogus.html"
CLASS
NAME "buoy"
SYMBOL "circle"
SIZE 8
COLOR 255 0 0
OUTLINECOLOR 0 0 0
LABEL
COLOR 255 0 0
TYPE BITMAP
SIZE MEDIUM
POSITION AUTO
PARTIALS FALSE
BUFFER 2
END # end of label
END
END
END
On Wed, 2003-02-05 at 14:26, Eric Bridger wrote:
> Using mapscript (mapserv 3.6.4) I am populating and drawing a layer with
> point objects. I'm getting lat,lon and a text label from a mySQL
> database, in other words, from a data source or connection type not
> supported by MS. What are my options for using layer->queryByPoint() on
> this layer, if any?
> Since I know the order I've added the points I can track the record id
> of the points. Do I need to create a dummy *.dbf file, a real *.dbf
> file? Is there some way to use MS_INLINE or perhaps layer->addFeature()
> or access the labels for the points created to allow me to query a layer
> created on the fly?
> Eric Bridger
> eric at gomoos.org Gulf of Maine Ocean Observing System www.gomoos.org
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
