[Mapserver-users] ProBlem Drawing a Line(circle) AS a second Layer on top the first Layer
    Terrence Lalla
    t_lalla20 at yahoo.com
    Thu Feb  6 16:14:14 PST 2003
--0-2054944181-1044576854=:28754
Content-Type: text/plain; charset=us-ascii
Hello all,
// the code
<?php
dl("php_mapscript_37.dll");
$map = ms_newMapObj("try1.map");
function Cal($x,$y,$radius)
 $lineObj = ms_newLineObj();
 for ($i=0 ; $i <=360 ;$i = $i +10)
  $angulo = deg2rad($i);
  $xcal = $x + ($radius*cos($angulo));
  $ycal = $y + ($radius*sin($angulo));
  $lineObj->addXY($xcal,$ycal);
 return($lineObj);
$array=$map->getAllLayerNames();
$p= ms_newpointObj();
$circle= ms_newshapeObj(MS_LINE);
$line= ms_newlineObj();
$layer = $map->getLayerByName('Circle');
$class = $layer->getClass(0);
$image = $map->draw();
$x=200;
$y=200;
$radius = 50;
$line = Cal($x,$y,$radius);
$test=$circle->add($line);
$test1=$circle->draw($map,$layer,$image,undef,"damage");
var_dump($line);
var_dump($test);
var_dump($test1);
$image_url = $image->saveWebImage(MS_GIF,1,1,0);
//end code
comments: the line show the $line->numpoints member containing the appropriate number of points. However for the $circle->add($line) the result returns int(0). I suppose that the process failed. Also, for the $test1=$circle->draw($map,$layer,$image,undef,"damage") the result returns int(0). Hence the circle layer is not drawn on top the first layer.
//mapscript code
NAME Trinidad
EXTENT 606030.98 1108051.15 739443.72 1201934.19
SIZE 400 400
UNITS METERS
SHAPEPATH "data"
WEB
IMAGEPATH "c:\apache\htdocs\tmp\"
IMAGEURL "\tmp\"
END
LAYER
NAME "Coastline1"
DATA coastline1
STATUS ON
TYPE line
CLASS
COLOR 220 220 220
OUTLINECOLOR 100 100 100
END
END
LAYER
NAME "Circle"
STATUS on
TYPE Point
CLASS
COLOR 220 220 220
END
END
END
//end mapscript code.
Can anyone suggest a possible solution to the problem ?
Also for the x,y, and radius values should I use pixel coordinates or georef coordinates for the map?
Thanks in Advance.
Terrence
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now
Content-Type: text/html; charset=us-ascii
<P>Hello all,</P>
<P>// the code</P>
<P><?php<BR>dl("php_mapscript_37.dll");</P>
<P>$map = ms_newMapObj("try1.map");<BR>      <BR>function Cal($x,$y,$radius)<BR>{<BR> <BR> $lineObj = ms_newLineObj();<BR> for ($i=0 ; $i <=360 ;$i = $i +10)<BR> {<BR>  $angulo = deg2rad($i);<BR>  $xcal = $x + ($radius*cos($angulo));<BR>  $ycal = $y + ($radius*sin($angulo));<BR>  $lineObj->addXY($xcal,$ycal);<BR> }<BR> return($lineObj);<BR>}<BR>     <BR>$array=$map->getAllLayerNames();<BR>$p= ms_newpointObj();<BR>$circle= ms_newshapeObj(MS_LINE);<BR>$line= ms_newlineObj();<BR>$layer = $map->getLayerByName('Circle');<BR>$class = $layer->getClass(0);<BR>$image = $map->draw();</P>
<P>$x=200;<BR>$y=200;<BR>$radius = 50;<BR>$line = Cal($x,$y,$radius);<BR>$test=$circle->add($line);<BR>$test1=$circle->draw($map,$layer,$image,undef,"damage");<BR>var_dump($line);<BR>var_dump($test);<BR>var_dump($test1);<BR>$image_url = $image->saveWebImage(MS_GIF,1,1,0);<BR>?><BR>//end code </P>
<P>comments: the line show the $line->numpoints member containing the appropriate number of points. However for the $circle->add($line) the result returns int(0). I suppose that the process failed. Also, for the $test1=$circle->draw($map,$layer,$image,undef,"damage") the result returns int(0). Hence the circle layer is not drawn on top the first layer.</P>
<P> </P>
<P>//mapscript code</P><FONT size=2>
<P>NAME Trinidad</P>
<P>EXTENT 606030.98 1108051.15 739443.72 1201934.19</P>
<P>SIZE 400 400</P>
<P>UNITS METERS</P>
<P>SHAPEPATH "data"</P>
<P>WEB</P>
<P>IMAGEPATH "c:\apache\htdocs\tmp\"</P>
<P>IMAGEURL "\tmp\"</P>
<P>END</P>
<P>LAYER</P>
<P>NAME "Coastline1"</P>
<P>DATA coastline1</P>
<P>STATUS ON</P>
<P>TYPE line</P>
<P>CLASS</P>
<P>COLOR 220 220 220</P>
<P>OUTLINECOLOR 100 100 100</P>
<P>END</P>
<P>END</P>
<P>LAYER</P>
<P>NAME "Circle"</P>
<P>STATUS on</P>
<P>TYPE Point</P>
<P>CLASS</P>
<P>END</P>
<P>END</P>
<P> </P>
<P>END</P>
<P></FONT>//end mapscript code.</P>
<P>Can anyone suggest a possible solution to the problem ?</P>
<P>Also for the x,y, and radius values should I use pixel coordinates or georef coordinates for the map?</P>
<P>Thanks in Advance.</P>
<P>Terrence<BR></P><p><br><hr size=1>Do you Yahoo!?<br>
<a href="http://rd.yahoo.com/mail/mailsig/*http://mailplus.yahoo.com">Yahoo! Mail Plus</a> - Powerful. Affordable. <a href="http://rd.yahoo.com/mail/mailsig/*http://mailplus.yahoo.com">Sign up now</a>
--0-2054944181-1044576854=:28754--
More information about the MapServer-users
