[Mapserver-users] optimizing shapefiles with the mapserver utilities?
Eric Davies
eric at barrodale.com
Tue Feb 11 16:17:02 EST 2003
--=====================_1884222390==.ALT
Content-Type: text/plain; charset="us-ascii"; format=flowed
I've got some fairly large shapefiles (> 100M) which I'm asking mapserver
to display.
I'd like to improve the speed at which it processes these large files.
I've already done the level-of-detail stuff (setting the minimum and
maximum scales at
which a layer is displayed), and I've built up the quadtree index with
shptree. However,
the latter didn't make much change to the speed.
My suspicion is that my shapefiles are relatively unordered, so that
elements for any particular small region are likely scattered across the
entire shapefile. What I'd like to do is order the shapefile so that
geometries that are geographically close together are more likely to be
close together in the shapefile.
The functionality to do perform this ordering is already present in the
utilities: shptree maps geometry locations to a linear key (the tile
number), and sortshp can reorder a shapefile based on a key. However, I
don't see any way to make the two talk to each other.
It shouldn't be too difficult for me modify sortshp to read in the shptree
produced index file, but before I do, I should ask if there is a way to do
this type of thing out of the box, without writing more code.
Thank you.
Eric.
Eric Davies, M.Sc.
Barrodale Computing Services Ltd.
Tel: (250) 472-4372 Fax: (250) 472-4373
Web: http://www.barrodale.com
Email: eric at barrodale.com
Mailing Address:
P.O. Box 3075 STN CSC
Victoria BC Canada V8W 3W2
Shipping Address:
Hut R, McKenzie Avenue
University of Victoria
Content-Type: text/html; charset="us-ascii"
<html>
<body>
<br>
mapserver to display.<br>
files.<br>
maximum scales at<br>
shptree. However,<br>
the latter didn't make much change to the speed. <br><br>
close together in the shapefile.<br><br>
don't see any way to make the two talk to each other. <br><br>
shptree produced index file, but before I do, I should ask if there
is a way to do this type of thing out of the box, without writing more
code. <br><br>
Thank you.<br>
Eric.<br><br>
********************************************** <br>
<x-sigsep><p></x-sigsep>
Eric Davies, M.Sc. <br>
Barrodale Computing Services Ltd. <br>
Tel: (250) 472-4372 Fax: (250) 472-4373 <br>
Web:
<a href="http://www.barrodale.com/" eudora="autourl"><font color="#0000FF"><u>http://www.barrodale.com</a></u></font>
<br>
Email: eric at barrodale.com <br>
Mailing Address: <br>
P.O. Box 3075 STN CSC <br>
Victoria BC Canada V8W 3W2<br><br>
Shipping Address: <br>
Hut R, McKenzie Avenue <br>
University of Victoria <br>
Victoria BC Canada V8W 3W2 <br>
**********************************************<br><br>
<br>
</body>
</html>
--=====================_1884222390==.ALT--
