[Mapserver-users] BUGS ?? pointObj->m, shapeObj->numlines and shapeObj->bounds not
set.
Luis Blanco
luis.blanco at retemail.es
Wed Feb 12 13:50:22 EST 2003
This is a multi-part message in MIME format.
--------------090709070200060100000800
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: quoted-printable
PHP MapScript - BUGS: pointObj->m, shapeObj->numlines and=20
shapeObj->bounds not set.
I have found the following bugs with Mapscript:
A simple bug related to pointObj, m member is supposed to be initialized =
to 0, but it isn't. If you try to initialize to a value, the value is=20
lost, it seems like it is initialized to the y value.
--- code begin ---
dl( 'php_mapscript.so' );
print ms_GetVersion();
print( "\n" );
$pto =3D ms_newPointObj();
$pto->setXY( 10, 20, 30 );
print_r( $pto );
$pto->setXY( 40, 50 );
print_r( $pto );
--- code end ---
--- ouput begin ---
MapServer version 3.6.1 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3D=
WBMP=20
SUPPORTS=3DPROJ SUPPORTS=3DTTF SUPPORTS=3DWMS_SERVER INPUT=3DEPPL7 INPUT=3D=
POSTGIS=20
INPUT=3DSHAPEFILE
point Object
[_handle_] =3D> Resource id #7
[x] =3D> 10
[y] =3D> 20
[m] =3D> 20 <----------------- this is wrong !!!
point Object
[_handle_] =3D> Resource id #8
[x] =3D> 40
[y] =3D> 50
[m] =3D> 50 <----------------- this is wrong also !!! :)
--- ouput end ---
The other (or others) are related to shape (ms_newShapeObj), more=20
exactly with shape.bounds and shape.numlines.
shape.bounds is not updated and neither shape.numlines, the latter is=20
supposed to be fixed according to
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0110/msg00394.ht=
ml
and
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=3D69
but it isn't.
--- code begin ---
print( "\n" );
$shape =3D ms_newShapeObj( MS_SHAPE_LINE );
$line =3D ms_newLineObj();
$line->addXY( 1, 2 );
$line->addXY( 3, 4 );
$shape->add( $line );
print_r( $shape );
--- code end ---
--- ouput begin ---
WBMP=20
POSTGIS=20
INPUT=3DSHAPEFILE
shape Object
[_handle_] =3D> Resource id #9
[numlines] =3D> 0 <----------------- this is wrong
[type] =3D> 1
[index] =3D> -1
[tileindex] =3D> -1
[classindex] =3D> 0
[numvalues] =3D> 0
[text] =3D>
[bounds] =3D> rect Object
[_handle_] =3D> Resource id #10
[minx] =3D> -1 <----------------- this is wrong also !!! :)
[miny] =3D> -1 <----------------- this is wrong also !!! :)
[maxx] =3D> -1 <----------------- this is wrong also !!! :)
[maxy] =3D> -1 <----------------- this is wrong also !!! :)
--- ouput end ---
Am I doing something wrong or something... ?
Any help is welcome.
luis.
--=20
{=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D
Luis Blanco email: luis.blanco at eresmas.com
Tlno.: 91 20 20 062
Wanadoo Espa=F1a - eresMas
www.wanadoo.es - www.eresMas.com
Direcci=F3n de Tecnolog=EDa
Edificio APOT
C/ Ribera del Sena, S/N, Planta 3
28042 Madrid
=3D=3D=3D=3D=3D}
Content-Type: multipart/related;
boundary="------------000800020608090908010600"
--------------000800020608090908010600
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type"
content="text/html; charset=ISO-8859-1">
<meta name="Generator" content="Microsoft Word 10 (filtered)">
<title>FW: Shell in the news</title>
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0cm;
font-size:12.0pt;
p
{margin-right:0cm;
margin-left:0cm;
font-size:12.0pt;
span.EstiloCorreo18
{font-family:Arial;
color:navy;}
@page Section1
{size:595.3pt 841.9pt;
margin:70.85pt 3.0cm 70.85pt 3.0cm;}
div.Section1
{page:Section1;}
</style>
</head>
<body>
<div class="moz-text-flowed"
style="font-family: -moz-fixed; font-size: 13px;" lang="x-western">PHP
shapeObj->bounds not set. <br>
<br>
I have found the following bugs with Mapscript: <br>
<br>
initialized to 0, but it isn't. If you try to initialize to a value,
the value is lost, it seems like it is initialized to the y value. <br>
<br>
--- code begin --- <br>
dl( 'php_mapscript.so' ); <br>
print ms_GetVersion(); <br>
print( "\n" ); <br>
<br>
$pto = ms_newPointObj(); <br>
$pto->setXY( 10, 20, 30 ); <br>
print_r( $pto ); <br>
<br>
$pto->setXY( 40, 50 ); <br>
--- code end --- <br>
<br>
--- ouput begin --- <br>
MapServer version 3.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=POSTGIS
INPUT=SHAPEFILE <br>
point Object <br>
( <br>
[<span class="moz-txt-underscore"><span class="moz-txt-tag">_</span>handle<span
class="moz-txt-tag">_</span></span>] => Resource id #7 <br>
[x] => 10 <br>
[y] => 20 <br>
[m] => 20 <----------------- this is wrong !!! <br>
) <br>
point Object <br>
( <br>
class="moz-txt-tag">_</span></span>] => Resource id #8 <br>
[x] => 40 <br>
[y] => 50 <br>
[m] => 50 <----------------- this is wrong also
!!! <img src="cid:part1.05030702.09010003 at retemail.es" alt=":)"
class="moz-txt-smily" height="19" width="19" align="middle"> <br>
) <br>
<br>
--- ouput end --- <br>
<br>
<br>
exactly with shape.bounds and shape.numlines. <br>
<br>
supposed to be fixed according to <br>
<br>
<a class="moz-txt-link-freetext"
href="http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0110/msg00394.html">http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0110/msg00394.html</a> <br>
<br>
and <br>
<br>
href="http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=69">http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=69</a> <br>
<br>
but it isn't. <br>
<br>
print( "\n" ); <br>
<br>
$shape = ms_newShapeObj( MS_SHAPE_LINE ); <br>
<br>
$line = ms_newLineObj(); <br>
$line->addXY( 1, 2 ); <br>
$line->addXY( 3, 4 ); <br>
<br>
$shape->add( $line ); <br>
print_r( $shape ); <br>
<br>
shape Object <br>
( <br>
class="moz-txt-tag">_</span></span>] => Resource id #9 <br>
[numlines] => 0 <----------------- this is wrong <br>
[type] => 1 <br>
[index] => -1 <br>
[tileindex] => -1 <br>
[classindex] => 0 <br>
[numvalues] => 0 <br>
[text] => <br>
[bounds] => rect Object <br>
( <br>
class="moz-txt-tag">_</span></span>] => Resource id #10 <br>
[minx] => -1 <----------------- this is wrong also
[miny] => -1 <----------------- this is wrong also
[maxx] => -1 <----------------- this is wrong also
[maxy] => -1 <----------------- this is wrong also
) <br>
<br>
) <br>
<br>
Am I doing something wrong or something... ? <br>
<br>
Any help is welcome. <br>
<br>
luis. <br>
<br>
<div class="moz-txt-sig"><span class="moz-txt-tag">-- <br>
</span>{======================================================= <br>
Luis Blanco email: <a class="moz-txt-link-abbreviated"
href="mailto:luis.blanco at eresmas.com">luis.blanco at eresmas.com</a> <br>
Tlno.: 91 20 20 062 <br>
Wanadoo España - eresMas <br>
<a class="moz-txt-link-abbreviated" href="http://www.wanadoo.es">www.wanadoo.es</a>
- <a class="moz-txt-link-abbreviated" href="http://www.eresMas.com">www.eresMas.com</a> <br>
<br>
Dirección de Tecnología <br>
Edificio APOT <br>
C/ Ribera del Sena, S/N, Planta 3 <br>
28042 Madrid <br>
=======================================================} <br>
<br>
<br>
<br>
</div>
</div>
</body>
</html>
Content-Type: image/gif;
name="smile_n.gif"
Content-Transfer-Encoding: base64
Content-ID: <part1.05030702.09010003 at retemail.es>
Content-Disposition: inline;
filename="smile_n.gif"
R0lGODlhEwATAKIAAP//AMzMAGZmAP8zAAAAAP///wAAAAAAACH5BAEAAAUALAAAAAATABMA
AANVWLrUTisyEoC1oUlFr8dQRHykFRad+Y0gdzlv86KVKdsskOUAjHu312rFK5GCRWDMJDAC
BKxGrTcFXTIo4CPY41QJgzAP69IWT14nWSL97DaiLVqRAAA7
--------------000800020608090908010600--
--------------090709070200060100000800--
