[Mapserver-users] Checkbox with java help
Kevin Slover
Kevin.Slover at noaa.gov
Thu Feb 13 08:50:41 EST 2003
BINGO!! Thanks Christian...
On a side note, is this due to jBox, and not using mapplet?? I notice
that other sites do not have that option within their code?? Just out
of curiosity..
Thanks again!!
christian.schuster at rsag.ch wrote:
> oh sorry I was to quick: It is not checked it is check
> So it would be like this
> <input type="checkbox" name="layer" value="florida_roads1" align="left"
> [florida_roads1_check] onClick="Refresh();" > Roads 1<br>
> Christian Schuster
> Rudolf Schuster AG
> Postfach 277
> CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
> christian.schuste
> r at rsag.ch
> Sent by: To
> mapserver-users-a "Kevin Slover"
> dmin at lists.gis.um <Kevin.Slover at noaa.gov>
> n.edu cc
> Mapserver Mailing-List
> <mapserver-users at lists.gis.umn.edu>
> 13.02.2003 14:44 ,
> mapserver-users-admin at lists.gis.umn
> .edu
> Subject
> Re: [Mapserver-users] Checkbox with
> java help
> Make sure that you also have the tag ["layer name"_checked] included in the
> html input tag.
> Change your input tag as following
> [florida_roads1_checked] onClick="Refresh();" > Roads 1<br>
> Christian Schuster
> Rudolf Schuster AG
> Postfach 277
> CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
> "Kevin Slover"
> a.gov> To
> Sent by: Mapserver Mailing-List
> mapserver-users-a <mapserver-users at lists.gis.umn.edu>
> dmin at lists.gis.um cc
> n.edu
> Subject
> 13.02.2003 14:36 java help
> Hello all!!
> Looking for a little bit of help right now. The small problem is as
> follows:
> I am using a checkbox to select which layer is to be displayed.
> Following a few of the examples out there, I have been able to get the
> display to refresh on click. However, the checkbox becomes unchecked.
> And I am only able to display one layer at a time... I am not sure where
> the problem resides, I have looked at several other sites, and they have
> the same code... mine is as follows:
> function Refresh(){
> document.mapserv.target = "";
> document.mapserv.mode.value = "browse";
> document.mapserv.submit();
> <form name="mapserv" method=GET action="[program]">
> etc.. etc... etc..
> I am using jBox, with version 3.6.4 on a RH 7.2. Any ideas!
> Thanks! Cheers!
> LTJG Kevin Slover, NOAA
> GIS Specialist/Oceanographer
> NOAA/TPC/TSB/Storm Surge Unit
> 11691 SW 17th Street
> Miami FL 33165
> W (305) 229-4456
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Miami FL 33165
W (305) 229-4456
