[Mapserver-users] Smoothing NEXRAD imagery
Daryl Herzmann
akrherz at iastate.edu
Thu Feb 13 18:57:11 EST 2003
Frank and others,
Thanks for your helpful response. I am not a very good c-programmer, so I
really appologize in advance for my ignorance.
Do nearest neighbour and cubic convolution code exist in GDAL?
I tell you all what, smoothing images would rock for many other purposes
than NEXRAD data. :)
Thanks,
Daryl
On Tue, 28 Jan 2003, Frank Warmerdam wrote:
>Daryl Herzmann wrote:
>> I have been working on generating maps of current NEXRAD (Weather
>> Service RARAR) imagery and overlaying observations. This is currently
>> working great, except the pixelation that occurs at very close range.
>> Does anyone know how to implement an automatic TIFF smoothing algorithm at
>> close ranges?
>> Here is a page with an example of what happens to the NEXRAD image at
>> close ranges... The pixelation at 25km is not that bad and will probably
>> be what I live with for the final app.
>Daryl,
>If you are using MapServer 3.7 from CVS there is a LoadGDALImage() function
>in mapdrawgdal.c that is responsible for most imagery loads from GDAL. It
>would be relatively easy to add a processing option to the map file that
>would direct this function to load oversampled imagery with some sort of
>smoothing - nearest neighbour or cubic convolution for instance.
>If you are feeling ambitious go ahead and take a crack at it. The processing
>arguments are generic all your changes would be in this one function.
>The special case to watch for would be when src_xsize > dst_xsize or
>src_ysize > dst_ysize. Just modify the code to loading into a data array
>at the source resolution and resample appropriate into the output buffer.
>I could do this, but I have little time available. Of course if you wanted
>to pay I am sure someone would be happy to do it.
>Best regards,
* Daryl Herzmann (akrherz at iastate.edu)
* Program Assistant -- Iowa Environmental Mesonet
* http://mesonet.agron.iastate.edu
