[Mapserver-users] How do I make a ploygon layer transparent
Martin, Daniel
DMartin at erac.com
Fri Feb 14 18:42:12 EST 2003
TRANSPARENCY 75
Put that within your LAYER object. Value is a percentage, with 100 being
totally visible and 0 being invisible. Only supported by newer versions of
Mapserver (3.6+ ???).
-Dan Martin
> -----Original Message-----
> From: Joseph Rodrigues [mailto:jorodrig at sfwmd.gov]
> Sent: Tuesday, February 11, 2003 3:37 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] How do I make a ploygon layer transparent
> I amtrying to layer two ploygons and have one as the base and
> the other
> on top. The base is a set of counties and the top layer are townships.
> Since both are ploygon, they block each other so I see a portion of
> both. I tried putting in the mapfile TRANSPARENT TRUE but it did not
> work.
> Joseph
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
