[Mapserver-users] did something change between 3.6.3 and 3.6.4?
Daniel Morissette
morissette at dmsolutions.ca
Sun Feb 16 09:49:57 PST 2003
Caffeinate The World wrote:
> I just upgraded from 3.6.3 to 3.6.4 and the demo gmap75 stop working.
> Here is what it does:
> http://www.minnesota.com/~tom/mapserver/demo/php/examples/gmap/htdocs/gmap75.phtm
> basically doesn't display an image. It used to in 3.6.3 using the same
> php-4.3.0.
If you do a 'view source' in the output of this page then you'll notice
that the HTML is truncated. This is likely an indication of a crash.
You could first look at your Apache error_log to look for hints.
There is nothing that changed between 3.6.3 and 3.6.4 to justify that
crash. So I suspect that your 3.6.4 build has some problem. Make sure
you don't have an old /usr/local/lib/libmap.a ... if you do then delete
it and redo your build.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
More information about the MapServer-users
