[Mapserver-users] did something change between 3.6.3 and 3.6.4?
woodbri at swoodbridge.com
Sun Feb 16 14:50:42 EST 2003
You might be able to get a better idea of what is going on by
cleaning out your tmp image dir and then running the gmap demp again
and see what if any images yet generated. This will clue you in to
how far it is getting before the crash. If you can ID where it is
crashing it might be easier to figure out what is going on.
Just a thought,
-Steve W.
On 16 Feb 2003 at 11:05, Caffeinate The World wrote:
> --- Daniel Morissette <morissette at dmsolutions.ca> wrote:
> > If you do a 'view source' in the output of this page then you'll
> > notice that the HTML is truncated. This is likely an indication of
> > a crash.
> > You could first look at your Apache error_log to look for hints.
> Nothing in the error_log at all.
> > There is nothing that changed between 3.6.3 and 3.6.4 to justify
> > that crash. So I suspect that your 3.6.4 build has some problem.
> > Make sure you don't have an old /usr/local/lib/libmap.a ... if you
> > do then delete it and redo your build.
> Everything was clean. But just to make sure, I removed all traces of
> the old 3.6.3 install and rebuilt 3.6.4. Same problem.
> I have the other tutorials (example1 and example2) working. Just when
> I got to the gmap demo it truncates the output. I suspect if there
> were problems with the mapscript php module 3.6.4 in general, it would
> fail on example1 and example2 as well. It didn't. Which leads me to
> believe that maybe gmap uses some function of mapscript that the other
> 2 examples don't use.
> Example1 demo:
> http://www.minnesota.com/~tom/mapserver/demo/php/examples/tutorial/exa
> mple1.phpc
> Example2 demo:
> mple2.phpc
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Shopping - Send Flowers for Valentine's Day
> http://shopping.yahoo.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
