[Mapserver-users] Classes based on Postgis && function
Benjamin Wragg
bwragg at tpg.com.au
Wed Feb 19 07:05:44 EST 2003
Hi Jan,
Thanks for your response. I tried putting the sql you provided into my
php script but received some errors regarding the 'case' word. I set it
up as shown below:
$layer->set("data","the_geom from (select table1.the_geom from
( select table1.the_geom,table2.the_geom, table1.oid
case when table1.fieldX = 'x' then 1
when table1.the_geom && table2.the_geom then 2
end as myclass
from table1,table2
where table1.id = table2.id
) as foo using unique=table1.oid using srid=-1)");
$layer->set("classitem", "myclass");
$class=ms_newClassObj($layer);
$class->set("expression", "1");
$class->set("name", "All");
$colorId=$GLOBALS['map']->addColor(255,0,0);
$class->set("color", $colorId);
$class->set("size", 20);
$class->set("symbol", 2);
$class->set("expression", "2");
$class->set("name", "Other");
It complains about the 'case' word. I can't find the 'case' statement in
any psql docs. Is it a psql or a mapscript statement?
I thought I should refine what I trying to do a little better. I'm
trying to display, in one class, all the features in a table where a
field equals a certain value. This will return a couple hundred
features. Then in a second class I'm trying to display all the features
where the same field equals this same value but only features that are
intersected by a feature in another table.
So I need to get the following sql statement translated into a
layer/class setup in MapScript:
SELECT sheet.thegeom
FROM sheet, userdefinedshape
WHERE sheet.the_geom && userdefinedshape.the_geom
AND distance(sheet.the_geom,
userdefinedshape.the_geom)=0
AND userdefinedshape.id='1'
AND sheet.type='something';
I played around with your example but couldn't get my problem to fit.
Any suggestions?
Thanks,
Benjamin
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Jan
Hartmann
Sent: Tuesday, 18 February 2003 11:39 PM
To: bwragg at tpg.com.au
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Classes based on Postgis && function
Benjamin,
You can use named computed variables in PostgreSQL:
end as myclass
from table1,table2
) as foo using unique=table1.oid using srid=...
after which you can use the new computed variable "myclass" as a regular
MapServer CLASSITEM. The computed values of this variable go into the
EXPRESSION statement:
CLASSITEM myclass
CLASS
EXPRESSION 1
COLOR ...
END
CLASS
EXPRESSION 2
COLOR ...
END
Jan
Benjamin Wragg wrote:
> Hi guys,
> Does anyone know if its possible to have a layer with two classes, one
> with a simple SQL expression and the other with a SQL statement that
> uses a PostGIS spatial function. Something like the following logic:
> class 1 = where table1.fieldX = 'x'
> class 2 = where table1.fieldX = 'x' and table1.the_geom &&
> table2.the_geom and table2.fieldY='Y'
> I can do it in two layers, but is it possible in one layer with two
> classes?
> Cheers,
> Benjamin
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
