[Mapserver-users] One-to-one JOINs added to CVS (3.7)
Steve Lime
steve.lime at dnr.state.mn.us
Wed Feb 19 11:53:48 EST 2003
Just an FYI for those who've been waiting patiently for this. Access to
Xbase joins at query
time has been added to the 3.7 source tree. I'll enable one-to-many
processing shortly and
will also be adding support for MySQL. This is essentially the
functionality that was available
pre-version 3.4. The ability to use JOINs for map making is being
considered but IS NOT
enabled at the moment.
The syntax is virtually identical to previous releases except that the
TYPE parameter now
requires the values ONE-TO-ONE or ONE-TO-MANY with the former being the
default.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
