[Mapserver-users] dynamic libraries and LDPATH
Madere, Colin
colin.madere at ieminc.com
Thu Feb 20 18:30:14 EST 2003
I'm on Solaris 8, no such LD config file :)
I've got mapserv CGI to run by wrapping it in a shell script that sets
LD_LIBRARY_PATH for the .so it was looking for, however, with PHP and
Mapscript it is a .so that loads a .so that loads a .so :) LD_LIBRARY_PATH
is not a solution there so I have to figure out how to get the linker to set
the paths to the shared objects that the php_mapscript.so needs.
> -----Original Message-----
> From: Madere, Colin
> Sent: Thursday, February 20, 2003 5:29 PM
> To: 'lehrs at erau.edu'
> Subject: RE: [Mapserver-users] dynamic libraries and LDPATH
> LD_LIBRARY_PATH is not a solution there so I have to figure out how to get
> the linker to set the paths to the shared objects that the
> From: lehrs at erau.edu [SMTP:lehrs at erau.edu]
> Sent: Thursday, February 20, 2003 5:26 PM
> To: Madere, Colin
> Not sure if this will help,... tryp this
> Look for the path that is listed.
> Then make sure this path is part of your runtime library path,
> for this you have two options, assuming you're running Linux:
> AS ROOT
> 1- add the path to the .so to the file /etc/ld.so.conf and run
> 'ldconfig' as
> root
> or
> This is from
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptBuild35
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Madere,
> Colin
> Sent: Thursday, February 20, 2003 6:18 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] dynamic libraries and LDPATH
> So I get an error trying to use Mapscript because when the .so is
> loaded by
> PHP it can't find the libwwwxml.so.0 (turning error output on shows
> the
> typical ld.so error when it can't find a library). I've been
> through _tons_
> of these issues and have made things work by setting LD_LIBRARY_PATH
> (yes, I
> know this isn't the best solution but for my testing environment I
> was ok
> with it).
> This does not, however, work for things that don't get the shell or
> user
> environment variables like CGIs or in this case a cgi that loads a
> library
> that loads a library :)
> So I found out that setting LDFLAGS = -R<location of libs> would
> instruct
> the linker to link in the library paths so that runtime resolution
> wasn't
> necessary. Considering the likely situation this stuff is to be
> used, I
> won't be changing where the libraries reside so this works for me.
> Unfortunately the configure/Makefile setup for Mapserver appears to
> use this
> variable only when checking compiler options for configuring and
> doesn't
> actually include it (LDFLAGS) when it compiles and links the project
> libraries and executables.
> Looking at Makefile.in I see an LDFLAGS being set but it does not
> appear to
> check (or I couldn't find it in configure or the Makefile.in) for an
> environment LDFLAGS to add to this so any environment set LDFLAGS
> gets
> ignored.
> Editing the Makefile after running configure to include my "-R<lib
> dir>"
> option in the LDFLAGS variable gets it in the linking commands and
> moves me
> to the next library error because another .so (not in that dir) can
> be
> found. If I add that dir to the end prefixed with the separating :,
> the
> error remains so I'm a bit stuck. Someone who knows a lot about the
> build
> process might check into the use of the environment LDFLAGS var in
> the
> configure/build for when the actual build process is happening,
> rather than
> just for the configure compiler checks...
> It seems that LDFLAGS isn't being checked or used at all in the
> Mapscript
> stuff (which is my current problem).. is that maintained solely by
> the
> MapLab people? Should I use that mailing list for compile/build
> issues with
> Mapscript?
> Fighting to get all this running,
> Colin
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
