[Mapserver-users] PNG24 bit not working for me
woodbri at swoodbridge.com
Fri Feb 21 09:57:51 EST 2003
Frank,
Great, that did the trick. I will file a bug to make the first user defined output block be the default. I think it will eliminate a lot of future confusion.
Many thanks,
-Steve W.
Frank Warmerdam <warmerdam at pobox.com> wrote:
> woodbri at swoodbridge.com wrote:
> > This is probably my bad, but I dont see the problem. I'm using a CGI query to
> > /cgi-bin/mapserv on RH8/Appache2/PHP-4.3.1 and mapserver built as:
> > MapScript Version ($Revision: 1.129 $ $Date: 2002/12/17 22:52:53 $) MapServer
> > version 3.7 (development) OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > The request gets and returns the geoTIFF raster data and returns a png file,
> > but it is an 8-bit png not a 24-bit png. The geotiff data is 3 band color
> > image (ie: 24-bits).
> > Does this mapfile look right? Is there a magic mapserver configure option I
> > missed?
> > built with gd-2.0.11 (gif patched), gdal-1.1.8, ogr, wms, wfs, ming. gdal was
> > built with the system png not the internal png.
> Steve,
> I believe that the IMAGETYPE defaults to the first one defined when not
> given explicitly, and there are a bunch of "implicitly" defined OUTPUTFORMATs
> that kick in first. So, I would suggest you add an IMAGETYPE png24 line
> in your mapfile.
> If you find this sufficiently annoying you could file a bug report/enhancement
> request to default to using the first _user defined_ OUTPUTFORMAT instead of
> just the first one in the internal list when an IMAGETYPE is not given.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
