[Mapserver-users] Classes based on Postgis && function
    Jan Hartmann
    jhart at frw.uva.nl
    Fri Feb 21 12:17:08 PST 2003
Later ...
I put parentheses around the CASE statement (before CASE and after END)
and now it works! Could you try this too?
Jan
Jan Hartmann wrote:
> Hmm, this looks like a bug: the two SQL statements are exactly the same,
> except for the USING statement. Also, the SQL in the error message is
> different from the original one (and definitely erroneous). Looks like
> the parser in mappostgis.c chokes on the combination of CASE WHEN and
> USING. In my own setup I have always run CASE statements without USING.
> I added USING now, and got the same error message. I guess the PostGIS
> folks should have a look at this.
More information about the MapServer-users
