[Mapserver-users] Raster: rotation params in WLD file
Lars V. Nielsen
LVN at gispro.dk
Sat Feb 22 13:49:46 EST 2003
Hi Frank,
Indeed it doesn't, it simply ignores the secondar parameters completely (I have tried).
> ..., but if you handle a raster through GDAL in MapServer then it
> can be rotated properly to display in MapServer.
Does this mean that I can use e.g. the below output format spec in 3.7 to display rotated raster images ?
OUTPUTFORMAT
NAME jpeg_gdal
MIMETYPE "image/jpeg"
DRIVER "GDAL/JPEG"
IMAGEMODE RGB
FORMATOPTION "QUALITY=80"
TRANSPARENT OFF
END
Best regards/Med venlig hilsen
Lars V. Nielsen
GisPro, Denmark
http://www.gispro.dk/
http://hjem.get2net.dk/lars-online/
WGS84: 10.20'40"E 55.20'20"N
----- Original Message -----
To: "Marian Grigoras" <mgrig at mnet-online.de>; "UMN MapServer" <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, February 22, 2003 7:01 PM
Subject: Re: [Mapserver-users] Raster: rotation params in WLD file
> Marian Grigoras wrote:
> > Hello,
> > Could someone please clarify what the 2nd and the 3rd paratemers in a
> > .WLD file mean?
> > All that I could find on the topic is that they are normally 0.00 :-))
> > and that is not very
> > encouraging if I want to define some raster maps that are not
> > North-oriented.
> > I tried to play with the parameters blindly, but I did not notice any
> > change in the output
> > image, whatever I write on these 2 lines. Are these parameters supported
> > at all?
> Marian,
> They are rotational coefficients.
> If W[i] is one of lines 0 through 5 of the world file you can calculate
> the georeferenced location of pixel [Xr,Yr] as:
> Xgeo = W[4] + W[0] * Xr + W[2] * Yr
> Ygeo = W[5] + W[4] * Xr + W[3] * Yr
> Most of the worldfile handling in mapserver ignores the rotational
> coefficients, but if you handle a raster through GDAL in MapServer then it
> Note that MapServer does not support producing rotated map results. They
> are always north up.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
