[Mapserver-users] Point color by attribute
Gerry Creager N5JXS
gerry.creager at tamu.edu
Sun Feb 23 10:08:10 EST 2003
OK, so the subject's not real clear.
I would like to be able to change the color attribute of a point object
in the mapfile based on a value retrieved from postgres. Can I do
something like this without dynamically rebuilding the mapfile every
time I access the database?
Specifically, when I'm building the shapefile, I'd like to have the
various points associated with a layer vary depending on their value, as
placed in the dbf.
In the link below, highlight 'Precip. Water Vapor' to see the values.
I'd like to make that selection A) display a point that is B) varied in
color with relation to the value of the PWV parameter.
http://mesodev.met.tamu.edu//cgi-bin/mapserv?map=%2Fvar%2Fwww%2Fmesonet%2Ftexas%2Fmesonet.map&layer=weather-metar&layer=weather-mtemp&layer=weather-mlabel&layer=weather-mdew&layer=weather-barbs&zoomsize=2&program=%2Fcgi-bin%2Fmapserv&map_web_imagepath=%2Fvar%2Fwww%2Fmesonet%2Ftmp%2F&map_web_imageurl=%2Ftmp%2F
Thanks, Gerry
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.4301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
