[Mapserver-users] Raster: rotation params in WLD file - Resampling
Frank Warmerdam
warmerdam at pobox.com
Mon Feb 24 17:01:25 EST 2003
Marian,
OK, I tracked through and it seems that since MapServer 3.6 I broket the
support for resampling raster files with non-zero rotation/shear coefficients
in the world file. I have corrected the MapServer 3.7 code in CVS and added
a test to the auto-test suite (msautotest/gdal/wld_rotate.map).
I now get correct operation with the following mapfile and world file. Thank
you for preparing the concise example for me to work with. The key issue a
user needs to keep in mind is to specify a projection in the MAP and LAYER (even
if they are just a dummy one like here) or the resampling logic can't kick in.
try.map:
NAME EX1
EXTENT 0 -558 880 322
SIZE 645 645
PROJECTION
"proj=utm"
"zone=12"
"datum=WGS84"
END
IMAGECOLOR 0 200 200
LAYER
NAME "map1"
DATA "map1.tif"
TYPE RASTER
STATUS DEFAULT
DEBUG ON
PROJECTION
"proj=utm"
"zone=12"
"datum=WGS84"
END
END # end of layer object
END # end of map file
map1.wld:
0.8660254
0.5
0.5
-0.8660254
0
0
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
