[Mapserver-users] 3.7 needing Oracle lib?
Tue Feb 25 07:22:11 PST 2003
Oliver Wesp wrote:
> Hi,
> This is not a real problem to me, I was just wondering. I recently
> compiled 3.7 (nightly.tar 02/23/2003) with
> ./configure --with-gdal=/path/to/gdal-config
> mapserver -v and ./mapserver from the shell worked fine. But as soon as
> I tried to use it via cgi an internal server error occurred. The apache
> log told me there was libclntsh.so.8.o missing. This is a library from
> Oracle. I added $ORACLE_HOME/lib to my LD_LIBRARY_PATH and everything
> went fine.
> But why is mapserver requesting this, although it's not compiled with
> oracle spatial support? And what if there is NO oracle on the server
> machine? Can anybody shed any light on this?
Oliver,
Sorry about that.  The GDAL makefile (GDALmake.opt) is currently automatically
including Oracle Spatial support in OGR if the ORACLE_HOME environment variable
is set when you build.  This should be controlled by a configure option but
currently is not.
To avoid this do a clean build of GDAL with the ORACLE_HOME environment
variable temporary unset.  libclntsh.so is a fair chunk of stuff to have
to load at runtime if you don't need it!
Best regards,
More information about the MapServer-users mailing list
