[Mapserver-users] converting to perl
Ed McNierney
ed at topozone.com
Tue Feb 25 11:09:34 EST 2003
Jon -
I'm not quite sure what your question is. Are you trying to get MapServer to process template files to generate Perl output that then gets processed and sent to the client? Or are you trying to use Perl to generate input for MapServer?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Tuesday, February 25, 2003 10:50 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] converting to perl
I am in the process of trying to convert a mapserver application to perl from
raw html. Here is a portion of my mcse.map file.
WEB
HEADER mcse_header.html
TEMPLATE mcse.html
FOOTER mcse_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in mcse_init.html"
IMAGEURL "set in mcse_init.html"
METADATA
WMS_TITLE "MCSE GIS Application"
WMS_ABSTRACT "This is the Demo of a GIS System for MCSE. It is based on
the mapserver demo application."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://172.16.40.17/cgi-bin/mcsegis/mcse_init.cgi"
WMS_SRS "EPSG:26915"
END
END
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
