[Mapserver-users] EXTENSION parameter in OUTPUTFORMAT removed?
Vinko Vrsalovic
vinko at cprsig.cl
Tue Feb 25 15:44:43 EST 2003
Two OUTPUTFORMAT curiosities:
1.- is EXTENSION parameter documented in the mapfile reference not
present?
PHP Warning: MapServer Error in loadOutputFormat(): (EXTENSION):(6)
in /var/www/html/sexta2.ms/index.php on line 23
The map file:
MAP
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
END
2.- I rendered a map with vectors and a raster 8 bits B/W layer. If I
used the default PNG outputformat, the vectors got rendered in B/W also,
if i turned the raster layer off, the colors were normal, if I turned on
the raster layer, all was rendered in B/W.
When using the outputformat I show above (without the EXTENSION, of
course) it gets rendered alright.
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
