[Mapserver-users] Raster: rotation params in WLD file -
Resampling
Steve Lime
steve.lime at dnr.state.mn.us
Wed Feb 26 16:33:33 EST 2003
The rule should be:
- check to see if DATA is absolute path, if so use it
- if not absolute, then check SHAPEPATH
- if not there, then check MAPPATH (location of mapfile)
There have been recent changes so this is likey a bug.
Steve
>>> Frank Warmerdam <warmerdam at pobox.com> 02/26/03 03:17PM >>>
Marian Grigoras wrote:
> Thanks Frank,
> It works now, although it took me some time to figure out that in
> MapServer3.7 (nightly build) a had to put the absolute path in
> the LAYER : DATA field. The SHAPEPATH was ignored.
> Is this a bug or a feature of 3.7? ;-)
Marian,
The path handling has changed substantially for 3.7. I believe the
raster files are supposed to be evaluated relative to the map file
now,
instead of relative to the SHAPEPATH directory, but I am not sure.
> Will 3.7 support rotated outputs? (Maybe I do not always want
> to see the maps North-up)
There are no plans for this, though through use of esoteric projections
it
is possible to generated rotated output - essentially fooling things
into
believing that north is in another direction.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for
Rent
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
