[Mapserver-users] Troubles with shapefiles
Alessandro Ceccotti alessandro.ceccotti at netxcalibur.com
Fri Feb 28 05:06:43 PST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_001B_01C2DF32.A2F577B0
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hello, I've got a problem using mapserver:
I've to insert a .shp file in my postgis db. I use shp2pgsql to create a
.psql file then, when I go to insert it in my database, it gives me the
following error:
4: ERROR:  pg_atoi: error reading "30390019695586": Numerical result out
of range
 NOTICE:  current transaction is aborted, queries ignored until end of
transaction block
It creates all the tables in db, but not populate it.
On what may be due to?
Thanks,
Ing.Alessandro Ceccotti.
Content-Type: text/html;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<TITLE>Messaggio</TITLE>
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DTahoma size=3D2><BR></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D703415611-28022003>Hello, =
I've got a=20
problem using mapserver:</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D703415611-28022003>I've =
to insert a=20
.shp file in my postgis db. I use shp2pgsql to create a .psql file then, =
when I=20
go to insert it in my database, it gives me the following=20
error:</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><SPAN class=3D703415611-28022003><FONT face=3DArial=20
size=3D2>"</FONT></SPAN></DIV>
<DIV><FONT face=3DArial size=3D2>4: ERROR:  pg_atoi: error reading=20
"30390019695586": Numerical result out of range<BR> NOTICE:  =
current=20
transaction is aborted, queries ignored<SPAN class=3D703415611-28022003> =
</SPAN>until end of transaction block</FONT></DIV>
size=3D2></FONT></SPAN> </DIV>
<DIV><SPAN class=3D703415611-28022003><FONT face=3DArial size=3D2>It =
creates all the=20
tables in db, but not populate it.</FONT></SPAN></DIV>
<DIV><SPAN class=3D703415611-28022003><FONT face=3DArial size=3D2>On =
what may be due=20
to?</FONT></SPAN></DIV>
size=3D2>Thanks,</FONT></SPAN></DIV>
<DIV>Ing.Alessandro Ceccotti<SPAN =
class=3D703415611-28022003>.</SPAN></DIV>
<DIV> </DIV></BODY></HTML>
------=_NextPart_000_001B_01C2DF32.A2F577B0--
More information about the MapServer-users mailing list
