[Mapserver-users] MapScript, help starting?
Lowell Filak
lfilak at medinaco.org
Fri Feb 28 16:26:57 EST 2003
There could be a few things causing that.
To turn on debugging see:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptDebugging
To find the "EXTENT" of "parcel" to make sure the data matches the mapfile try:
<mapserver_unpack&compile_dir>/mapscript/perl/examples/shpinfo.pl
-file=parcel
For examples see:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35
But then replying to a "Junkmail Box" may not be a good decision on my part.
HTH
Lowell F.
The following message was sent by Junkmail Box <junkmail at deathkeep.com> on Thu, 27 Feb 2003 08:33:35 -0800 (PST).
> I'm having trouble getting started using Perl MapScript. The doc at
> http://mapserver.gis.umn.edu/doc36/perlmapscript-reference.html doesn't
> give a lot for examples of getting started. They do give this, though:
> #!/usr/bin/perl
> use mapscript;
> my $map = new mapObj('arcata.map') or die('Unable to open mapfile.');
> my $img = $map->draw() or die('Unable to draw map');
> my $void = $img->saveImage('example.png', $mapscript::MS_PNG, $map->{transparent}, $map->{interlace}, 0);
> However, when I run it, example.png is an empty file.
> Any ideas on what the problem could be?
> Are there any tutorials on getting started using MapScript?
> arcata.map is a map file, and works with the mapserv CGI binary just fine.
> And $map->{numlayers} properly says there are 3 layers in the map. So I
> know mapscript is seeing the arcata.map file, and that arcata.map is
> valid. The arcata.map file is as follows:
> # map file - Arcata demo
> NAME ARCATADEMO
> STATUS ON
> SIZE 504 504
> EXTENT 407375 4522866 410627 4526910
> UNITS METERS
> SHAPEPATH "/usr/local/mapserv/htdocs/arcata"
> IMAGECOLOR 255 255 255
> IMAGETYPE JPEG
> # web interface definition
> WEB
> # the template for browsing mode
> TEMPLATE arcata.html
> MINSCALE 1000
> MAXSCALE 1550000
> IMAGEPATH "/usr/local/mapserv/tmp/"
> IMAGEURL "/tmp/"
> END
> # reference (thumbnail) map
> REFERENCE
> EXTENT 404958.660383 4520848.011905 413035.327051 4528936.011905
> SIZE 216 216
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> ## legend - automatically generated from any classes that have a NAME
> attribute
> #LEGEND
> # KEYSIZE 18 12
> # LABEL
> # TYPE BITMAP
> # SIZE MEDIUM
> # COLOR 0 0 89
> # END
> # STATUS ON
> #END
> # scalebar
> SCALEBAR
> IMAGECOLOR 0 0 0
> LABEL
> COLOR 255 255 255
> SIZE medium
> END
> STYLE 1
> SIZE 288 6
> COLOR 255 255 255
> UNITS MILES
> INTERVALS 4
> TRANSPARENT TRUE
> STATUS ON
> END
> ### LAYER DEFINITIONS
> ### parcel divisions
> LAYER
> NAME parcels
> TYPE POLYGON
> DATA parcels
> STATUS OFF
> # what template to use for displaying a query about a parcel
> TEMPLATE /usr/local/mapserv/htdocs/arcata/parcel_query_template.html
> # when labeling parcels, the owner's name is the label to use
> LABELITEM OWNER_NAME
> # color-code certain parcels, depending on the owner
> CLASSITEM OWNER_ADD
> CLASS
> #EXPRESSION "ARCATA PLAZA"
> EXPRESSION /ARCATA*/
> COLOR 128 255 255
> OUTLINECOLOR 0 255 0
> LABEL
> COLOR 0 0 0
> END
> END
> CLASS
> EXPRESSION /CALIFORNIA*/
> COLOR 200 200 200
> LABEL
> COLOR 0 0 0
> END
> END
> # default parcel coloration
> CLASS
> NAME "Parcel"
> COLOR 255 120 120
> LABEL
> COLOR 255 255 255
> END
> END
> END
> ### creeks
> LAYER
> NAME creeks
> STATUS OFF
> DATA creeks
> TYPE LINE
> CLASS
> NAME "Creek"
> COLOR 0 0 255
> END
> # template to use if someone queries a creek
> TEMPLATE creeks_query_template.html
> END
> ### roads
> LAYER
> NAME roads
> STATUS ON
> DATA roads
> TYPE LINE
> CLASS
> NAME "Road"
> COLOR 0 0 0
> LABEL
> COLOR 128 128 128
> END
> END
> # label roads, and allow a user to query a road
> LABELITEM FNAME
> TEMPLATE roads_query_template.html
> END
> ### END OF LAYER DEFINITIONS
> END # end of map file
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
